JFP in PA
  1. About average. First of all, these units do not drain 100%, and some people drain them, add some fluid, then drain them again to try and flush out all the old fluid. In the shop, we drain out all that will come out and then refill them to the correct level, which is important. Get more fluid and correct the level; these units are too expensive to replace over a small amount of additional fluid.
  2. You should be able to read the MAF signal voltage with the Durametric software.
  3. A drive cycle is cold start, fully warmed up, drive at highway speeds, shut down, and sit until cold. Any variation in that chain and it is not a full cycle.
  4. The process is not just cold starts, it is cold starts, complete warm up, drive at highway speeds, shut down and complete cool down; repeat. These are known as "drive cycles" as mandated by the EPA. On some models it can happen fairly quickly (50-100 miles), on others it runs longer (200-500 miles).
  5. They will bill you for diagnostic time, ask them what they charge. The shop would have to have a factory PIWIS unit.
  6. You need to have your fuel pressure and delivery checked, which requires some special equipment due to the high pressures involved. A failing fuel system does not always result in codes.
  7. First of all, it is always useful to state the year and model of the car involved. Getting a "not ready" for the secondary air injection system is a common issue with these cars, some taking a couple hundred miles of driving to reset by themselves. Yes, dealers can force the issue if needed.
  8. All Ctek models include a desulfating step in their charge cycles which many other maintainers (like Deltran) do not, which significantly adds to the life of all battery types. Most Ctek models also have a special AGM cycle as well.
  9. Most maintainers (never use a trickle charger on any type of battery, they are battery killers, pure and simple) are capable of handling AGM batteries, some even have specific charge profiles to take maximum advantage of the AGM technology; but at the end of the day, an AGM is a lead acid battery, just in a different physical form.
  10. Welcome to RennTech Sorry to hear about your bad news in your first post. If I were in your boots, I would not be looking around Toronto for someone that might be able to do it, but look for who is the best M96/87 engine builder period, who unfortunately is not even in Canada, but does have shipping arrangements for vehicles literally all over the world: Jake Raby at FlatSix Innovations in Georgia. He is not cheap, but his engines are killers, and he even runs a school that teaches other engine builders. Jake developed the IMS retrofit procedures widely used today, and has even developed some excellent tooling for working on these engines. Several board members here have attended his school, and several run his engines. Give them a call, they will work with you to get you the best possible replacement: Jake Raby There aren't many shops I would personally recommend, but his is one that I would without reservation.
  11. AGM batteries offer many pluses over a conventional flooded cell: Way better shock/vibration resistance, much longer lived (sometimes 2-3X a flooded cell, I recently replaced a 12 year old AGM because it failed a load test but never failed to start the car), and they are sealed, which means no corrosion on the battery tray and surrounding areas which is a critical issue with these cars.
  12. It sounds like the fans are getting an erroneous signal. You need to scan the vehicle, pulling fuses is not going to isolate the issue.
  13. Welcome to RennTech This is going to be both complicated and potentially expensive. Your car is equipped with pulse width modulation controlled fans which use a signal from the DME to control their fully variable speed controllers. If the PWM fans have gone bad, there is no fixing them, they have to be replaced, and they ain’t cheap. I would suggest scanning the car with a Porsche specific scan tool (PIWIS or Durametric) and looking at two things: Check your engine temperature sensor for correct readings, and test the fans them selves.
  14. The interior sensor is the one above the inside review mirror, and the system is saying it is defective. I’d suggest looking at the sensor assembly above the mirror.
  15. There are several sources of this type of info, but one of the best is board sponsor Sunset Porsche's part catalog website where you can find anything: Sunset Porsche Parts Catalog
  16. Hate to let the wind out of your sails, but the engineering is not as sound as you might think. The DOF draws oil from a cylinder head, which is well known to be both one of the hottest and dirtiest sources of oil. Ask anyone that rebuilds Porsche cylinder heads about how difficult it is to clean out cylinder heads during a rebuild and you will understand better. There have also been multiple reports of problems with both the VarioCam systems and lifter noise when pulling oil from the heads, both of which ceased when the oil line was plugged. And, as all versions of the OEM IMS bearing seals are know to leak oil into the shaft itself, there have been questions about what that does to the loads on the IMS bearing itself. While some have had success with this design, there are a lot of unanswered long term questions that remain definitively unanswered. If you want a very well designed and proven retrofit system, look at the IMS Solution. It uses a solid bearing that gets its oil feed directly from the oil filter adaptor, which is obviously the cleanest source of oil, and one of the coolest. The system also uses a plug in the shaft behind the bearing to permanently prevent oil intrusion into the shaft. Both of these features are part of multiple patents, which is why no one else uses them. The IMS Solution has no moving parts, and is also the only permanent fix for the IMS issue, and the only retrofit bearing that can even be moved from one engine to another if needed. And yes, it costs a bit more, but this is definitely an area where "you gets what you paid for".
  17. You are correct about tints as some of them contain metallic materials which can totally block a detector. For best reception, the detector should be mounted as high as possible without being blocked by tints. Valentine Research, manufacturers of the highly regarded V1 detector have an excellent "white paper" on their website about optimum mounting locations. Mounting the device has many options, from suction cups to mechanical mounts that suspend from the rearview mirror mount, but all are a matter of personal choice usually based on cosmetic appearance issues. You need to do some research in this area to make a decision. There are multiple hard wiring options available, all you really need is access to a wire that is hot with the ignition in the on position, and a good ground. Some people have used the wiring for the dome light controls above the mirror. As for which brand, you will get a lot of opinions, most based on personal preferences rather than actual performance. My personal choice is the V1, which offers 360 degree detection, bogey counter, and unlimited upgrades as new threat technologies pop up. My choice is based upon reading side by side performance reviews, and nearly 20 years of never being hit with a ticket from radar or laser that went undetected as I have roamed all over the US. Others will probably chime in to tell you this or that brand is better, but to date I have not seen another device to equal the V1's history of consistent performance. Do your homework, you are buying something to keep you out of trouble, so know what you are buying. Good luck.
  18. Probably the axel flange seals going bad.
  19. Welcome to RennTech Unfortunately, even the owner's manuals for these cars are considered the copyrighted intellectual property of Porsche, which precludes RennTech, or any other legitimate website, from publishing in any form. Fortunately, the are also relatively inexpensive and available from any Porsche dealer.
  20. It sounds like you definitely have and intake air leak that is affecting both banks.
  21. Welcome to RennTech 996/997 cars are well known for their intermittent electrical issues after washing. Run the car and drive it for a bit around the neighborhood to dry everything out; if it still does it after that, you need to scan for codes.
  22. Used cats out of a wreck.
  23. Depends upon how much work you are ready to do. The PSM system is a complex network of pumps, hydraulic lines, sensors, and control electronics, all of which will need to be swapped, flushed and bled, and then programmed in the final vehicle. Do able? Yes. Worth the effort and expense? That is up to you.......
  24. Aftermarket transmissions are probably twice the length of the Porsche unit, and simply will not even fit in the space, and again, they have no differential, which would make the combined package way too large to fit period. If a Porsche dealer was to undertake this project, which I seriously doubt they would do, your prices would literally skyrocket, probably doubling or even trebling what an independent shop would charge. They would use new or factory remain parts, so your flywheel would be $1500, the gear box around $9500, etc. Add in the dealer's exorbitant labor rates, which are typically twice (or more) those charged by an independent shop. and the project would exceed the cost of buying a complete second manual transmission equipped car; probably well in excess of $20K, which is just plain nuts.
  25. I don't see how you could do this with something other than a Porsche/VW/Audi type trans axle as the transmission and differential is a single and very compact unit. Aftermarket transmission's are just that, a transmission without a differential.
