JFP in PA
  1. It doesn't take much. Something as seemingly innocuous as reproducing a page from a car's owners manual is enough to get the lawyers knocking on your door.
  2. A lot of things in the public domain are not legitimate, particularly on the internet. Posting such things puts RennTech at risk of being shut down, which is why we cannot permit it.
  3. "Copyrighted material: By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this site. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted."
  4. Guys, you are posting copyrighted intellectual property of others, something you specifically agreed not to do when you joined RennTech....................... Please remove the links or we will...................
  5. These pumps often take a "set" to the housing and need to be "coaxed" out. Don't go animal on it, but work it from side to side until it loosens up.
  6. Welcome to RennTech Yes, the immobilizer/security system computer does not recognize the pill in the key, because the "handshake" is programed into the 2.7 DME. This would require reprograming the RFID code into the 3.2 DME, but without the original key code tags, is not possible. You will need to flatbed the vehicle to a dealer with a PIWIS unit, buy two new keys with the code tags, and have them reprogram the DME, or get the entire ignition switch and keys from the donor car and swap them over.
  7. As you will need to disassemble the strut to replace the bearing, the bump or any other bits that are showing wear are fair game as well.
  8. Basically. Slow speed grinding noises are quite often these things giving up the ghost. You can test them by putting your hand or a stethoscope on each one and having someone turn the wheel.
  9. More likely, it is the upper strut bearing.
  10. The only way to rule out the DME is through diagnostic's, so there is going to be at least some $ involved. And just as a side note on the subject, in all the years we have been working on these cars, I have seen very few DME failures, fewer than I can count on one hand.
  11. Even a used DME (same version number) would require reprograming by a PIWIS system. The DME in these cars is the center of everything, even your odometer miles are stored in the DME.
  12. See the above; testing or replacement is going to require the Porsche diagnostic system......................and bring money as a new DME is about $2K sitting in a box on the counter, plus and hour or two of programing time, if it really is the DME.......
  13. Don’t take this the wrong way, but I think you have too much time on your hands. First of all, being a shop, we see a lot of different examples of just about every car, and basically none of them sit completely level. Depending upon suspension age, tire wear, modifications, and allowed factory tolerances, they are all leaning one way or another slightly. Having said that, what you really need to determine is how level is the spot you park the car at home, and if that area is relatively level (again, almost none are absolutely level), and use that as your oil level reference point. With the car sitting in that spot, and stone cold (like having sat there overnight), your oil level should be about one bar below the top mark. Once it has checked out there, ignore what the level sensor says at any other location, or at any other time than the first thing in the morning, stone cold conditions. People seem to forget that it can take hours for all of the oil to drain back into the sump after even a short running period, and oil in the sump takes hours to cool back down after running, so worrying about different readings in different locations, or after the car has been run is not a useful exercise.
  14. That is going to require access to a Porsche factory diagnostic system such as the current PIWIS or earlier PST II.
  15. Opps! You are correct, I was thinking of the older single row classic which reused the OEM snap ring?. The outter clip on the single row pro is another reason the Faultless tool is required for installation as it hold that clip in the retracted position until if finds the shaft grove during installation, and is the only tool that can do that during installation.
  16. When the Faultless tool is pressing the new bearing into the shaft, because of how well it aligns the bearing with the shaft, relatively little effort is required; it just cranks in using a ratchet handle. When the bearing bottoms out, suddenly you can’t turn the tool any longer. Simple and effective. Think of the Faultless Tool as being much like a large C clamp, when it bottoms out, the force required to turn further rises exponentially. Remove the tool and you should just see the snap ring groove inside the shaft, just ahead of the bearing. Insert and seat the snap ring, and the new bearing is in. It is just that simple. That is why the tool has the name it has, it is truly Faultless. With the engine locked at TDC, the one bank locked, and the hydraulic tensioners removed, the engine isn’t going anywhere. Never be concerned about asking lots of questions, I worry far more about people who don’t ask............
  17. Because of how the Faultless tool works, cooling the bearing is not required. If you feel better doing so, go ahead and cool it, but it is not necessary. The single row pro bearing is a much more complex design bearing in order to get the two rows into the same space, which makes it susceptible to damage if installed incorrectly. The Faultelss tool prevents this from happening. When to stop is simple: The bearing bottoms out in the shaft, and the tool will not go further. You are done. The cam holding notches are different on the three chain engines, so no, the five chain tool will not work, and is in fact not needed. Follow the instructions and you will be fine. DO NOT USE SET SCREWS ON THE IMS SHAFT. If there was one thing I and other shop owners wish had never been published, it would be this item. Pushing on the IMS shaft gear with set screws can dislodge and even cock the chain gear, at which point you are totally screwed, and the engine has to come out and apart. We have had multiple cars flatbedded to the shop after their owners did this. Don’t do it. The result is going from and upgrade to an totally engine rebuild.
  18. To my knowledge, there are no connections for PASM in the engine bay. Unless your “techie” has one of the Porsche specific diagnostic systems, he won’t be able to help you as the systhem controller uses proprietary Porsche software.
  19. Welcome to RennTech First place to start is get the car scanned with a Porsche specific diagnostic tool (PST II, PIWIS, Durametric) to find out what is going on.
  20. Welcome to RennTech Now you know why we recommend a full pre purchase inspection by an independent shop. Misfires are probably coils and/or plugs. The P5400 is a “sport mode” fault that will require diagnostics with a Porsche specific scan tool to determine what is going on.
  21. There were multiple variations of this trim, different by year, model (cab vs. coupe, turbo vs. non Turbo, etc.) which is probably why there was never a clear write up. Personally, I just put my glasses on, provide lot of light, and have at it. None of them are overly complicated or tricky, just lots of push pins, clips, and screws that typically reveal themselves.
  22. A lot of disassembly and clips, I have never seen a step by step for this:
