JFP in PA
JFP in PA last won the day on May 13
JFP in PA had the most liked content!
About JFP in PA
Contact Methods
  • Website URL
    http://
    Earth.........
    02 S......
17,506 profile views
JFP in PA's Achievements
Community Answers
  1. Is the metal ferrous (can be picked up by a magnet)? A photo would be helpful.....
  2. Without actually seeing the car, it would be pure speculation of what is needed, and caliper studs or bolts, it still has to come apart, but sometimes using studs actually slows down the process because they are simply in the way when the caliper has to come off............
  3. Most noise issues are related to how the pads were installed; did they use the correct lubricants and install noise dampeners if so equipped? If the current pads have not been done correctly, just replacing them will typically get you to the exact same place.............
  4. Which tells me there is nothing wrong with either your guides or the chains themselves. Looking at the photos you posted of the guides, they look like the newer design, possibly indicating that they have already been replaced. If that is the case, the debris in your sump may be the wear bits from the old units.
  5. What were the cam deviation values for the engine? Spec is +/- 6 degrees; when these cam pads are too worn, we see deviation values in the high single digits due to excessive slack in the chains.
  6. Just be sure to get the latest version, we have never had any problems with the OEM replacements.
  7. The easiest and probably cheapest way as well is to add a small amount of coolant compatible UV dye to the system and run the engine for a bit. The dye will leave a highly visible (with a UV light source) trail to exactly where it is coming from. We use this technique regularly in the shop to trace difficult leak sources.
  8. I don't see why it wouldn't work, but overspeed pulley adds a complication and potential future failure point that the fixed pulley does not have.
  9. Back in the day, I remember them being optional parts. There are currently multiple used sets on eBay, and there were some aftermarket suppliers as well, such as an outfit called Dido Tuning :
  10. They may no longer be available due to the part's age, which is not uncommon. You might check with a dealer to see if any still are on the shelf somewhere in the system.
  11. A scan of the car with a Porsche specific tool (Durametric, PIWIS) can identify if the M535 anti-theft/immobilizer system (Central Locking Unit or CLU) is present and functioning. Diagnostic tools like Durametric or Porsche System Testers can query the alarm module for error codes, confirming its status. This system is also located under the driver's seat.
  12. Check your fuel trims, bet at least one bank is running lean.
  13. We have seen quite a few complaints of engine speed related noises being tracked down to bearings going bad in tensioner rollers, water pumps, alternators, etc. I would start by removing the belt and trying to rotate the various components by hand, which often identifies the problem unit without even starting the engine. Everything should turn smooth and quietly; anything that doesn't should be suspect.
