gandrade1
Everything posted by gandrade1
  1. Hi guys, The answer to this question seems very obvious - use a bigger diameter if you can. However, considered the price of track tires in larger sizes and the fact that my car has limited HP, how much would I actually benefit from using 18's instead of 16's on my 01 Boxster with track tires for DE events? Do I actually need the extra contact area or are the 16's just fine. Please, mind you that not too long ago the 16's were standard in 911's with the same engine displacement as my Boxster...And, boy, aren't the Boxsters more predictable for a unnexperienced driver like me?!? Please, see this as a cost/benefit analysis, rather than a straight forward tire diameter recommendation! All opinions are welcome... Best, Gus
  2. Click over his name in this thread and select 'Find Member's Topics' Best, Gus
  3. Hi Manny, Did you notice these are not Brembos? If I were to go for a brake upgrade, I would most likely try to get the Brembo (OEM) calipers... Anyone else? Best, Gus
  4. I do not have this one, but I have one built EXACTLY like it. It resonates between about 2600 and 3000 rpm and drones down low around town. Thats in a sweet spot for about 65mph on the highway too. With the top down it isn't objectionable, but with the top up it gets old. It does sound sweet as hell above 3000 rpms though. Enough so that I have lived with the resonance for a year. But now I'm looking for another solution with less resonance. Hi Andy, Just curious what solution you found.... Am thinking about an exhaust upgrade for my 01 Boxster, but don't want to spend too much. I heard very good reviews of the Maxspeed exhaust, which also happens to have a good price - around $580 All the best, Gus
  5. Thank you so much, azzar0 I will take a look tonight if it is as simple as getting the screw aligned I will fix it right there. Otherwise, If I need to remove the liner I will wait until Sunday. Thanks, Gus
  6. Hi guys, Last weekend I removed the front bumper for radiator cleaning+horn replacement. I put it back and everything looked fine, except for the right (passenger) side wheel liner, which took some effort to put back in. Basically I had to push it a little to get the rivets aligned with the roles. Then I noticed a small gap (right in front of the wheel) between the lower part of thE liner and the bumper. :( Could that mean that my front bumper is not properly aligned? If so, why would all the other screws and rivets fall into place without any force...By looking at the bumper and its distance to the front trunk lid and headlights everything looks even. How can I confirm that the bumper is aligned and that only the liner has to be dealt with? I intend to fix it on Sunday - right after a PCA Car Control Clinic event on Saturday. Is there any risk of damage if I wait until Sunday - that would mean skipping the event on Saturday :cursing: ? Thank you so much, Gus
  7. Has anyone come across a roll-bar extension lately? Best, Gus
  8. Did this car have all the options you are looking for? If yes and the price is right...I would go for it! Plus, Terracota is not a very common color, which might differentiate the car a bit and I believe you would grow to love it... In the end if the car handles the way you like, the optionals and the exterior color are right you will get used to the color of the leather! That's my personal opinion! All the best, Gus
  9. ... besides I have to wrap my head around pulling off the front bumper cover! :huh: That was for me the toughest part! I reassembled it, but I guess I need to re-align the right wheel liner a little better, since I ended up with a small gap in the bottom part, which I don't remember being there! Other than that the bumper itself seems to be pretty aligned. BTW, I would definetly recommend jacking the car up and removing the front wheels (which I didnt do, but now recognize the mistake) - it will save you a lot of time when dealing with those IMAGINATIVE, CREATIVE, INVENTION OF THE CENTURY plastic rivets and will save your hands from scratches and the arms from bruises! All the best, Gus
  10. Anything like this for the 986 (base Boxster) ???
  11. Hi Karst, I love your enthusiasm, man :cheers: We are talking about 2,872 mi :o I would more than gladly help you with the horn replacement and would greatly appreciate your help with the short shift install...But those would be two expensive replacements, considered the current price of gas!!! If you are serious though, you should probably plan ahead of time and take some time to visit the area (New York City specially) - that combined with the experience of taking your car on a road trip across the country might be a worthwhile experience. Thank you so much. All the best, Gus
  12. Hi guys, I did replace the horn by myself....My next mod is the B&M Short Shift Install Anyone willing to help in the NJ/NY area? All the best, Gus
  13. Thank you so much, ToolPants... Thanks to you, Loren and others here I removed the bumper this weekend by myself, cleaned the radiators and replaced the stock horns with the 3 trumpets... The result is amazing! BTW, I broke only one rivet. All the best, Gus :renntech: Updates on the material used: (1) Same bracket as in ToolPants pics (from HomeDepot) - 2 feet long...They only sell 3 or 4 feet, but one of the guys there was VERY kind as to cut the bracket for me, after some convincing. (2) 2 M8 bolts, with regular nuts and locker washers. (3) Insulated crimping connectors (4 in my case, but usualy 2 for other styles) (4) Electrical tape (5) 16 AWG electrical wire (6) A lot of patience and care, while removing and re-installing the bumper.
  14. I hope it is the last time I bother you with this mod :unsure: Quick questions: (1) What is the distance between the two brackets for the 3rd radiator - in other words - how long does the sheet metal bracket needs to be? I just thought you guys might have the info readily available, I am planning on going to the hardware store during lunch. Otherwise I will just go home in the end of the day and measure it. (2) What size of bolts and lock washers do I need, in order to attach the bracket? I read something like M8 - is this readily available at any hardware store? All the best, Gus
  15. Thank you so much, Loren... Thas great news! :renntech:
  16. I am also removing the stock horns and replacing them with an air horn kit on my base 986 (MY01). Based on ToolPants postings I found a place to mount the horns and learned how to secure them. I have no clue on how to run the electrical connections, however. I would like to keep the electrical connections very simple since all I know is that I need to get a positive wire and a negative wire to somehow connect to the back of the compressor. Can anyone please clarify which wires to splice - I was hoping I could just use the positive and negative connections that run to the back of either the low/high OEM pitch horn and connect them to the back of the compressor. I am planning on simply covering with electrical tape the two terminals that go to the OEM horn I will not use. Simply, my questions are: 1) Can I just splice the two OEM horns, isolate the terminals that go to the back of one of them and use the other 2 to connect to the compressor? 2) From the pair of terminals I choose, how do I know which one is the negative and which one is the positive? Are they color coded? 3) Since I am mounting the compressor in the center of the bumper (where the 3rd radiator would be) I need the terminals to reach there, so I am simply planning on buying regular 16 gauge wires and running from the original terminals to the center of the radiator - How do I secure my connections? Can I just use electrical tape and 'crimp' the connectors that go to the back of the compressor? PS: I dont have a soldering machine... Sorry for the many and most likely obvious questions... Best, Gus
  17. Anyone has a pic of where these infamous rivets are located? Thanks, Gus Did you read the DIY instructions? They are on the wheel well liners. Just want to make sure I don't miss any of them...I did read the DIY - great by the way. Thanks, Gus
  18. Anyone has a pic of where these infamous rivets are located? Thanks, Gus
  19. Hi guys, Just got a Hella 3 trumpets horn and I would like to install it in my 01 (base) 986. I have read that the front bumper removal is a much smoothier process if done by two people. I was wondering if anyone would like to help and take the opportunity to remove the bumber on his car as well to clean the radiators, which I also intend to take the opportunity and do on mine. I live in Jersey City (Newport/Pavonia area), I have 4 jack stands (we only need one pair per car), a low profile hydraulic jack and an assortment of tools. My space is limited but we could try the parking lot in front of my house if it is a nice day out. I am also open to other locations. Best, Gus
  20. Hi Robert, Simply put, if you buy 17's with the same offset and bolt pattern (5x130), they will fit right in. If you buy a larger offset, let us say 55mm instead of the 50mm in the rear, you will most likely need 5mm spacers, if you buy a lower ofset let us say 40mm, you will already be 10mm further out, so no spacers can save you! I found this nice website you can play with Offset Calculator Best, Gus
  21. :welcome: There you go: 6J X 16 @ 50 mm (front) 7J X 16 @ 40 mm (rear) 7J X 17 @ 55 mm (front) 8.5J X 17 @ 50 or 48 mm (rear) Best, Gus
  22. Oh man, Really wish I could be there! Loren, do you have an estimate of how many members Renntech has in the New York/New Jersey area? Maybe someone could take a stab at organizing something like this in this area... I would, if only I had access to a ample garage and parking area. Best of luck, guys... Gus
