boxster99
Everything posted by boxster99
  1. I thank you very much for your assistance. I will go to the dealership in the morning and see what they have to say.
  2. Is this a major problem where I should be concerned very much? Or Is it an easy one day fix kind of thing? Im gald that My warrantee covers all these parts but Im seriously thinking about changing the car if this matter will affect any other mechanical parts in the future.
  3. Man this sucks!!!~ I was driving off to buy some coolant since the coolant level was low. And then suddenly, I saw some smoke comming out from the rear!! And the temperature warning light started to blink!! I stopped the car and ran to the store and got some coolant and added it with water, waited for the car to cool down and started the engine. The warning light was now gone but there is some weird *** squeaking noise from the engine!! What could this be?? Now my car is sitting put I will have to make a visit to the dealership in the moring ASAP. HELP!!
  4. Is this problem covered under warrantee? Thank you so much
  5. I discovered a small puddle of green liquid under the car. Looks like antifreeze but not really sure. Leak seems to be comming from around the center point between the rear wheels and onto the plastic cover then onto the ground. Please help! What could it be? Just thinking about the repair cost is starting to get on my nerves. My car is a 99 boxster.
  6. Thanks for all the opinions!!~ Anyone try snow with all season M+S rated tires? Thanks again
  7. How many of you drive your boxster in snow? With a good set of snow tires does it get around ok? How about driving on summer tires with snow chains on? What are your opinions? Thanks
  8. Interesting, totally different opinions... Im must make a poll and see what the results are... Thanks
  9. Im curious to see how often boxster owners change their engine oils.
  10. How realistic is it to change oil and filter every 15,000 miles? Even though the manual recommends changing oil every 15,000 miles or 1 year, I'm not sure if this really true. Anyone have any opinions on this? Thanks
  11. Thank you so much!! I will try it out right now
  12. where exactly should I tighten? Is it the large copper bolt above where the cable connects to the car? Thank you so much!
  13. When driving at high speeds over 70mph, my rear part of the cabrio starts to shake/vibrate crazy. I don't know if it is the plastic window but it gets really annoying. Does anyone have a similar problem or a solution? Thanks.
