jam996
Everything posted by jam996
  1. Hi, the fuel door on MY99 won't lock, I see a pin coming out when I lock doors but it won't lock fuel door. any ideas what could be the reason. thanks
  2. I had a quote for the exchange transmission, 11k can. :cursing: but I heard it could be fixed for half the price.
  3. Is there a harness and relay for the retrofit interior auto-dim rearview mirror? I found a factory replacement one for 996s that had it as an option already, Is there any harness for that? anyway to install it..? thanks
  4. :censored: Thanks Loren.
  5. Hi, Im having a little problem with my gears... When I shift to second gear it pops out back to neutral. Its happening more and more, Im wondering what could be the cause. thanks
  6. It said somewhere in this forum that its stock height when PSS9 in maximum level..? Im going for this setup because in case there is rubbing I could just adjust it higher, and isn't the stiffness adjustable too on these suspension? thanks
  7. Hi, I finally decided to lower my C2 99 w/ 19's and looking to get PSS9s, I don't know if my tires will rub so Im getting these adjustables. Does anyone know how low is the maximum height on PSS9s compared to stocks? What other parts do I need, I heard GT3 sway bar and some other, any part number if oem? thanks.
  8. Thanks alot Richard :cheers: btw ordered it from dealer/Germany and is about 500 w/extra for quick delivery.
  9. Thanks Loren, how do I find which relay to change? its not mentioned in the TSB about which relay to replace.
  10. Is there a DIY for this retrofit, how do I find the original relay to be replaced?
  11. I wish I knew a bit more about this before I purchased my wheels 19" 8.5/10.5 and the tires size everyone kept recommending was 275/30 rear and 235/30 front. but the wheel comes out of the tire as if tire is not wide enough.. Isn't that dangerous?? the installer told me its ok. Ive never seen that before and dont want to get into an accident to find out. Im a bit confused about what to do, should I get wider tire or if its safe just drive it for the summer and switch back to 18" for next summer. please let me know if it is safe to take out my Porcha. btw I have MY99 C2 coupe. thanks
  12. nice, post some pics of your Porcha. :thumbup:
  13. Loren, the link doesn't work anymore, can't seem the DIY. how to replace trunk/hood release handles. can you post it again plz. thanks
  14. Ive started the facelift, got all the parts I and am taking pics for a complete DIY that I will post very soon. Body shop has the parts for prep. and Ill take my car in for the swap and complete paint and wiring next week. btw I have an extra set of the wire you need to do the facelift. PM me if interested. Pics of Pcar before conversion.
  15. thanks alot Richard :cheers:
  16. Is there a part # for the pin removal tool?
  17. I have a set of these wires and will let them go for a reasonable price, PM me if anyone interested. thanks
  18. Cut off done, much better! If I want to add just a little more sound to my PSE, what would be the best thing to do. not that Im not happy with how it sounds, but I think I would prefer just a little more.. thanks
  19. thanks for the tip HP :cheers:
  20. I also need the same diagram but for 02+ bi-xenon to complete my conversion. Can someone help me with this. thanks
  21. Its a caractere bumper made for 996, and it fits your 01C4. PM me for more info or pics. thanks
