jam996
Everything posted by jam996
  1. Thanks for the quick reply Loren, thats what I thought at first, didn't check it 'cause if it has anything to do with front connector or wires then what explains the rear light not working. brake light is ok.
  2. and its only on the right side. xenon is working just low beam, side marker and rear light.
  3. When headlight switch doesn't work the fuse blows right away? do you have the part number for the switch, Is this a common problem? thanks Loren
  4. Im having a problem with my lights, front low beam side marker and rear light don't work. I have a blown fuse on A3, changed it but blows again as soon as I turn on lights. Any ideas, anything else I can check before taking it to garage/dealer? what about the relay?
  5. here is the link for the install with switch from the 986 section http://www.renntech.org/forums/index.php?showtopic=23307
  6. Why the switch does not stay "ON"? I have to hold it down to turn on lights. any ideas?
  7. Can someone correct this if Im wrong ground to light. power to both pins on switch. wire from horizontal pin on switch to light. thanks
  8. how to wire these lights??
  9. finally I have some some time to do this mod.. If I want to do this with two lights using the switch in dash, and wiring it with the telephone plug, do I need to put a fuse so It doesn't cause any damage? Can someone PM me with some help on how to connect all this together. thanks
  10. Yes, there is both switched and unswitched power on the telephone prep connector. brown and green/black wire?
  11. Hi, Im trying to install this switch with some lights for footwell area, I know there is a mod hooking up the power wire to interior lights so they can dim, but I want these footwell lights to be connected to the switch only. Where can I get power for these lights? Can I use the telephone plug (under center console) power wire? thanks
  12. where does these cable hook on the tranny? how do I check it? thanks
  13. HI, something wrong with my C2's gears... Its as if the shifter cables are not connected, Its loose and won't get into gear. So I removed the center console to look if the shifter cables were connected, and they are. So where could the problem be? thanks
  14. would you a link to this mod on the web?
  15. Hi, I recently retrofitted a rain sensor on my C2, Since I don't need the in-dash manual wiper switch, I was wondering if I could replace it with something else... what about a engine start button. Please share some thoughts. thanks
  16. Disconnect battery, then remove door panel : unclip door handle cover, remove 2 screws, another behind door handle and one inside door pocket, remove airbag crest with butter knife/screwdriver, and unscrew the last screw. Finally unclip door panel from sides and base, the just lift out. carful for the wires behind. Unplug airbag.
  17. help please for the code, going on a trip, sucks with no radio
  18. hi Loren, cdr-220 4462 15061901 thanks
  19. I believe the bulb on 02+ headlights are different than 99-01 996's.. where can I buy higher temp bulbs?
  20. Hi, I was wondering if its possible to upgrade the bi-xenon headlights bulb and fog lights to something brighter? any recommendations?? thanks
  21. Hi guys, my window makes a squeeking sound. could it be that door panel is too tight, I recently had it removed for speakers upgrade, but that was 2 weeks ago, and the noise started yesterday.
  22. thanks guy, great tips. If It can avoid me buying new tranny, or at least get it at 2500$.
  23. plastic catcher not there, thanks Loren and RFM. btw my alarm beeps twice, I figured it the fuel door. Will it get back to normal mode once my fuel door locks or do I have to get it reset?
  24. thats what I thought by reading some threads, but 11k is from Porsche in Canada. How can there be such a difference in price? will there be any guarantee if I buy it from US?
