jam996
Everything posted by jam996
  1. Im thinking of removing my rear seat belts, since I took the seats. Is there a trim to replace the belt outlet in C pillar? thanks
  2. Hi, I bought a pair of 996 sport seats with silver painted back. I currently have full power seats w/ memory, and the sport ones are electric on just the back, not the lower part. Do I need different harness? will the memo function still work?? thanks
  3. I removed my headliner on my C2 coupe, Any instruction on how to remove sunroof liner? thanks
  4. Its not clear how to remove seatbelt from C Pillar?
  5. Hi, any instructions on how to remove the rear pillar (with speaker). thanks
  6. For those who don't have rain sensors, and want to keep intermittent wiper switch, I just did some re-wiring and the module works now with a in-dash switch!!
  7. You have to turn key and put in the position where all lights come on.
  8. I will post a video on youtube sometime this week.
  9. Both, I have a 6speed, but will work with tip as well.
  10. Takes about 30 min. to install. Clutch switch is bypassed!
  11. thanks. The cap is originally red with engine start written in white, Im customizing mine... I wired up a power outlet light trim, to give it a oem look. I have a spare set assembled, if anyone interested pm me.
  12. here are some pics, lettering on switch coming up.
  13. Hi guys, I installed a rain sensor in my 996, so I had no use for the intermittent wiper switch. I started looking into what to replace it with, didn't had alot of option, another power outler? what about a start button?? So I tried a couple of universal kit out there, but they either didn't work or switches really didn't match with the interior decor, or ran the battery down. So I customized a kit with the proper relay and wires, and found a switch, which sits flush with the trim. A kit specifically for the 996s. Now all I gotta do is put the key in, press the button and voila!! B)
  14. Do I have to unplug any hoses?
  15. I need to change my right side radiator bracket, can someone please give me some detailed info on this. thanks
  16. Hi, Is 997 3.6 air intake the same as 997 3.8? and how much is retail for these?
  17. Loren, do you know what wires comes from the barrel?
  18. I heard here someone installed it on the boxster section and worked out nicely... I still have to put the key in and turn it to last position and then press button. I thought I had to connect it under dash, behind ignition?
  19. Hi Loren, Im trying to install a engine start button kit, it requires me to hookup the two wires from kit to the leads coming from ignition barrel that lead to the starter motor solenoid. In this case, are we talking about two yellow wires from 50? How to locate these wires easily? thanks
  20. sorry forgot to mention, 99 C2 coupe.
  21. Hi, Where are the ignition wires located, I mean more precisely the lead coming from the ignition barrel that lead to the starter solenoid, and what color is 12v and ground? thanks
  22. Hi, My alarm chirps once when I lock the doors, and if it doesn't chirp alarm goes off after a couple of minutes. I got it scanned(forgot the code) but was something about unsyncronised keys, but keys work fine. any thoughts?? thanks
  23. C3 if for interior lights and take a look at B7 for brake lights.
