jam996
Everything posted by jam996
  1. Hi, Im about to install a gsr sirius kit on my '11 cayenne S, and am looking to get constant power source from fuse box, which fuse I can tap into? thanks
  2. Hi guys, I was wondering what is needed to fit a turbo engine into a C2. I have a great deal for a wrecked 997tt, so needed to confirm what exactly I need for this conversion. thanks
  3. Hi, On my pcm 2.1 navigation, location is way off all the time. I checked the software version by pressing MAIN and TRIP, scrolled down to navigation, there is a triangle with a exclamation point inside, and there is no info on the software version. Any ideas what could the problem be?
  4. Sorry, Wing is off a 2010 TTurbo, so I need diagram for that.
  5. Hi guys, I just bought a used wing with hydraulics and wires are cut, found a connector for it, just need the diagram where to connect each wire. Anyone with the wing wiring diagram? thanks
  6. Is it possible this might be the reason my battery is drained if I don't use the car for couple of days? Should I remove the fuse to check if thats the problem?
  7. Hi, I have a 05 C2, When the car is turned off with key removed, I hear the pcm making a noise (a sound of ejecting a CD). sometimes when I open the door to get inside, I hear same noise from the pcm.. Is that normal, Has anyone else had this issue?
  8. Yes ofcourse, MY05 997 C2 coupe, from misha wing no light, to vorsteiner vrt wing with spoiler light. Thanks
  9. How to get to the third brake light wires on the body?
  10. Hi guys, I changed my spoiler from a fixed spoiler w/o brake light to one with a brake light, Didn't want to pay over a 100$ for a new harness again.. I have the connector for the brake light, my question is where is the best place to connect it so It lights up when I brake, tail light, the other 3rd brake light on car, or on the harness? Any suggestion? thanks
  11. Hi guys, Im doing a full car wrap on my 05 997coupe, I need to remove the door handles. I searched but haven't found anything, can someone help me with how to do that? thanks
  12. Thank you Loren, This is exactly what I was looking for. It should be in the DIY section.
  13. Door panel is already off... Just the storage lid looks tricky.
  14. Hi, Im giving my door handles and door storage lids to redo the leather, I got the door panels off, removed the handles but can't seem to figure out how to remove the storage lids?!? Any tips? thanks
  15. Where can I get 12v switched power, and ground in the footwell area? Thanks
  16. Having the same problem with my 05 C2, any updates? Is there a fix to this?
  17. Try Ebay for a used headlight, lens is not avaiable seperately.
  18. Ok, got some time tomorrow to finish the install. I am still not sure if I need it that short line, why is it in the kit then..?? Any ideas?
  19. I don't see anything about this on the TSB either.
  20. One vacuum line goes to each valve on the left and right silencer , these then connect into a Y shaped rubber piece which then goes back to the solenoid valve. The other side of the solenoid valve goes to the inlet manifold vacuum point take off , on some cars this involves another Y piece connected after the take off point , to allow the variocam plus solenoid and the PSE solenoid to share the same vacuum point. On my own car I also fitted a simple switch in series with hte solenoid actuation wiring to allow the PSE to be controlled independently of the car ECU. The benefits are the PSE doesnt go quiet at certain speeds and can be left operational all the time without the need to activate , every time the car is started. So only 3 lines, one each for mufflers connected to Y shape and to solenoid valve, and the other from vaccum to U shape plastic(protective tube) on solenoid valve. Right? the short 125mm one not needed? thanks
  21. Hi, Im installing a PSE on my 05 C2, and am a bit confused with reading the TSB on the install...I get the change over valve setup, and the electronics, but am not sure about how those plastic lines are connected inside engine bay, and I have an extra one of 125mm, is that needed? thank you
  22. I finished the install, everything seems to be working fine, except that on the map signal loses track every once in a while. Is it in some kind of learning mode or do I have to reprogramme it with dealer?
  23. So you saying 2mm is ok as long is there is no rubbing to caliper, right?
  24. Im installing my 19" wheels on my C2 05, they are deep dish style and at the rear, the wheel's face is very close to the brake caliper, about 2 mm. no rubbing but looks tight. Is it ok or should I put 5mm spacers? thanks
  25. thanks Loren, Will try that in the morning and give updates.
