jam996
About jam996
Contact Methods
  • Website URL
    http://
  • ICQ
    Montreal
    Porsche 996 C2
    Mercedes C230 Kompressor
  • Future cars
    Porsche 997 C2S
    Audi A4
    Bmw 740
    Porsche 911
1,336 profile views
jam996's Achievements
  1. Hi,
    I read that more than 10 years ago, you had the same problem with the 996 transmission, that I have now.
    Mostly if cold, sometimes my 2nd gear pops out immediately after releasing the clutch. Did you try changing the fluid (to Redline?) as suggested? Did that help? Or maybe you tried the GBox detent? If possible I would like to avoid the exchange of the synchro ring for a while.
    Thanks a lot you your help!!
    Thormann
  2. Hi, Im about to install a gsr sirius kit on my '11 cayenne S, and am looking to get constant power source from fuse box, which fuse I can tap into? thanks
  3. Hi guys, I was wondering what is needed to fit a turbo engine into a C2. I have a great deal for a wrecked 997tt, so needed to confirm what exactly I need for this conversion. thanks
  4. Hi, On my pcm 2.1 navigation, location is way off all the time. I checked the software version by pressing MAIN and TRIP, scrolled down to navigation, there is a triangle with a exclamation point inside, and there is no info on the software version. Any ideas what could the problem be?
  5. Sorry, Wing is off a 2010 TTurbo, so I need diagram for that.
  6. Hi guys, I just bought a used wing with hydraulics and wires are cut, found a connector for it, just need the diagram where to connect each wire. Anyone with the wing wiring diagram? thanks
  7. Is it possible this might be the reason my battery is drained if I don't use the car for couple of days? Should I remove the fuse to check if thats the problem?
  8. Hi, I have a 05 C2, When the car is turned off with key removed, I hear the pcm making a noise (a sound of ejecting a CD). sometimes when I open the door to get inside, I hear same noise from the pcm.. Is that normal, Has anyone else had this issue?
  9. Yes ofcourse, MY05 997 C2 coupe, from misha wing no light, to vorsteiner vrt wing with spoiler light. Thanks
  10. How to get to the third brake light wires on the body?
  11. Hi guys, I changed my spoiler from a fixed spoiler w/o brake light to one with a brake light, Didn't want to pay over a 100$ for a new harness again.. I have the connector for the brake light, my question is where is the best place to connect it so It lights up when I brake, tail light, the other 3rd brake light on car, or on the harness? Any suggestion? thanks
  12. Hi guys, Im doing a full car wrap on my 05 997coupe, I need to remove the door handles. I searched but haven't found anything, can someone help me with how to do that? thanks
  13. Thank you Loren, This is exactly what I was looking for. It should be in the DIY section.
  14. Door panel is already off... Just the storage lid looks tricky.
  15. Hi, Im giving my door handles and door storage lids to redo the leather, I got the door panels off, removed the handles but can't seem to figure out how to remove the storage lids?!? Any tips? thanks
