fitsintite
    RDP
    Boxster
fitsintite's Achievements
  1. Hi, your car looks nice, I have a 1997 and would like to change the door panels also, My questions are did you connect the airbags to actualy function, how much did you pay for the leather panel and how good was the fit. Thanks
  2. Took me 30 seconds to find this place :huh: http://cgi.ebay.ca/6-PORSCHE-PREM-HIGH-PER...id=p3286.c0.m14
  3. I used red engine paint, clear, and decals from eBay, most important thing is to use a good degreaser and then brake cleaner, you spray 3 light coats of paint,put the decals, and 3 light coats of clear and you are done.
  4. I think it's to defrost the door mirror and you have a short in that box somewhere.
  5. There is a black junction box where the door hinges are, this box has male and female plugs in there, open it up and check to see if the pins are corroded. If they are corroded find a way to clean, fix or replace them. I would start with that.
  6. The inside of my head lights also look awful and I would want to know if there is a fix for this.
  7. Hi Placid I just finished a top cover install using instructions from Mike's site and also downloaded work shop manuals from this place. http://www.cannell.co.uk/Manuals.htm Look in PDF Group 6 Body Equipment, Exterior Good Luck :)
  8. Hi Guys, Thanks to this thread I solved my drivers side window not working. Culprit was the junction box electrical contacts in the door, same as above rusted and disconnected from female pins. Took me only 1 hour to fix the problem thanks to you great guys. Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks
  9. Hi, This guy called Franco on the 986forum.com found water coming in from the welds in the wheel well where the rocker panel is spot welded to the frame. Smart guy. :) http://986forum.com/forums/showthread.php?t=8274
  10. Hi, congratulations
  11. Did you know RennTech.org has a full option listing for most Porsche's? It is located here Hi Loren, The reason i gave another site was because Patrick mentioned "I did a search here on the forums but couldn't find exactly what I was looking for." Sorry
  12. Hi Patrick, Maybe you are mistaking P37 $867 $678 Traction Control with ABD (Active Brake Differential) for LSD. Just a thought, check out this site http://www.986faq.com/default.asp for all options available on the 986. My opinion if you are looking to buy a 1997-1999 Boxster, choose one with the least millage and minimum electronic gadgets and get it checked by a Professional that has worked on these cars and has an idea where to search for weaknesses. Just my honest 2 cents. Good luck.
  13. Hi Robert, Google "Leatherique" they have a kit for renewing steering wheels. I'm redyeing my seats as we speak, got one done and it looks awesome, i also got the steering kit and will be doing that this winter.
  14. I will be removing the old shiny cardboard textured dye using lacquer thinner and the re-dye will be done with Leatherique Products. I could have changed the color but decided to stay with the original, sent them a sample I cut out which they used to replicate the exact same color.
