Mikelly
Contributing Members-
51 -
Last visited
Classifieds
Everything posted by Mikelly
Air Con/Heating Fuse D6 Keeps Blowing
Mikelly replied to logray's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Well as it would happen, I think the compressor was “stuck”. I jumped it to the power lug and it started working the clutch fan. Now plugged back into the 30 Amp circuit and it’s working. -
SOS... Digging up an old thread. I replaced my compressor, as it was dying, now the new one is cracking the D6 fuse on my 1999 Carrera. -
AC Compressor issue
Mikelly replied to Mikelly's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Fixed. Replaced the old clutch and shims and it works, strangely enough. Little bit noisy. I may end up trying the new clutch with the old shims. But for now it works. Mike -
AC Compressor issue
It’s Mike Kelly. I’ve been around since 2007 and wrote a BUNCH of tech articles when I was running the 996TT 30 track days per year. So I checked the airgap and added an extra shim because it seemed to rub against the the hub and was dragging. Now it’s not engaging at all. I’ll measure the air gap. Thanks. -
Gang, I had a noisy issue withthe engine bay where I though it was the belts/pulley's and swapped out the tensioner and guide pulleys, along with a new belt, then found the noise was actually in the HVAC compressor when the AC was turned on. So, per searching this forum I found the suggestion of replacing the AC Compressor clutch and pulley/bearing assembly. So I ordered a refurbished unit and "borrowed" these items and installed them. I now am the proud owner of a 911 with NO functioning AC. The system turns on but it doesn't seem like the clutch actuates. The hub is magnetized when I turn the ignition on, but the clutch doesn't seem to actuate and the system is not blowing cold air. I'm looking for suggestions.
The F pipe DIY link is here: http://www.renntrack.com/forums/showthread.php?1984-996TT-DV-Replacement-DIY Mike
996 Tutbo to GT2 Front Bumper and Aero Conversion DIY GT2 Front Bumper and Aero conversion DIY By Mike Kelly March 25,2011 First, I must thank Hawk(Erik) for his help in getting some of the hard parts early on, and my boys atSuncoast (Ryan in particular) for helping me with endless questions, andproviding parts at the right price when I needed them. I couldn't have donethis without their help. Pay very close attentionto the Red Text here and at the bottom of this “story”. The below is Author Mikelly Category TT/GT2 (996) - Mods Submitted 03/27/2011 05:08 AM Updated 03/15/2017 05:21 AM
Mikelly posted a tutorial in TT/GT2 (996) - Mods
GT2 Front Bumper and Aero conversion DIY By Mike Kelly March 25,2011 First, I must thank Hawk(Erik) for his help in getting some of the hard parts early on, and my boys atSuncoast (Ryan in particular) for helping me with endless questions, andproviding parts at the right price when I needed them. I couldn't have donethis without their help. Pay very close attentionto the Red Text here and at the bottom of this “story”. The below is a list of theparts I ended up BUYING: The numbers for theseparts were: 996-505-311-30-G2XBumper Cover 996-505-563-30-01CAir Inlet 996-505-564-30-01CAir Inlet 996-505-561-30-01CAir Inlet 996-575-326-30Bumper frame (front diffuser) 996-575-325-30Bumper Air Duct 996-505-741-30-01CBumper HID 996-505-742-30-01CBumper HID The other hardware tosimply turn the radiator upside down and mount everything so it lines up is asfollows: 996-505-773-32Spacer Panel (x2) 996-505-531-30Retaining 996-575-321-30Air Routing 996-575-322-30Air Routing 996-504-195-30Radiator Bracket (Upper) 996-504-679-31Spacer Sleeve (x2) 996-504-413-30Radiator Bracket (Lower) 996-575-141-30Cooling Air Duct 996-504-123-90Inner fender liner 996-504-124-90inner Fender Liner There are about 20 partnumbers related to water lines required in order to do this swap to OEMstandards: 996-106-422-75Hose return 996-106-740-91Hose 996-106-641-75Hose 996-106-136-91Breather Hose 996-106-127-53Vent Line 996-106-615-54Water Tube 996-106-623-53Hose 996-106-627-52Hose 996-106-611-53Hose 996-106-615-54Water Tube 996-106-627-52Hose 996-106-624-53Hose Return 996-106-652-54Water Tube 996-106-651-54Water Tube 996-106-127-53Vent Line 996-106-546-54 YPipe 996-106-126-54Vent Line ® 996-106-225-54Vent Line (L) 996-106-621-75Center Radiator Hose ® 996-106-625-75Center Radiator Hose (L) Here is what the pile of“waterline” parts looked like in the floor of my reading room: So as has been reportedelsewhere, I bought a bumper and associated parts from another member in latesummer 2010. I sat on the project until I could get enough technicalinformation on the project from aerodynamic, cooling, fit and finish, as wellas functionality standpoints. What I wanted to achieve was the best overall OEM“like” install I could. I didn’t want to use worm clamps and spliced waterlines if I could help it, didn’t want to relocate the horns, as others havedone, and I didn’t want to have mis-matched parts that would look “wrong”. I thinkI got it right… Read on. The biggest problem fromthe outset was finding a water line schematic for routing the $600 worth ofwater lines I bought from Suncoast Porsche. Upon further inspection, it became reallyclear that to do it “right”, you’ll have to remove the differential and open upthat whole “valley” that exists under it. This routing runs up to the bonnetand then snakes around each side, fishing between the fuel tank, storagecompartment and fender wells. I’d been warned that this was no easy task andthat I should reconsider what I was thinking of doing. So I wanted to start witha clean shop, all bits laid out on the floor so I could look at them, and thecar opened up without plastic panels in the way. So Friday afternoon I spent anhour doing just that… Once done, I was ready to start the removal of the frontbumper. To do this, you actually start in the bonnet. This plastic trim panelis held on with four small plastic screws. Turn them counter clockwise ¼ turnto release the panel. Careful when removing it as the trim runs up the side ofthe fender between the bonnet framework and the headlights. Be gentle removingit or you’re likely to break it. I also remove the light inside the luggage compartment,so you don’t drain the battery. Tools needed: TORXbits and driver Phiilips#2 screw driver Smallhead flat screw driver (mainly used to pry lightly) 16MMsocket and/or wrench (Bumper structure) 13mmsocket/ratchet and wrenches (radiator bracketry) 10MMsocket/ratchet and wrenches (replacement bolts for bumper structure mounts) 8mmsocket (removing the rear panel bolt under the car) Longneedle nose pliers Vicegrip pliers Somethingto cut rubber water hoses with (Razor blade or hose cutter) Drilland bit to drill out rivets in radiator air duct Poprivet gun and rivets to re-attach new duct to old radiator Flashlight The following steps can befound in detail in the factory service manual. Next I removed to thefender liners… Removing them is easy, and doesn’t require removing the wheels,but certainly is easier if you do so. I just turned the steering wheel side toside as needed to get to the 4 TORX screws and plastic “push pin” fastener atthe marker light within the wheel well. Once you have the innerfender liner portion unbolted, you can remove the side marker light and unplugit so it doesn’t get in the way or scratch the finish. Now move to theunderside of the car and finish removing the rest of the torx screws and “pushpin” fastener in the brake air guide. There are a total of 21 screws(15 torx and 6 Phillips) and four nylon push pin type fasteners that hold theinner fender liners, spoiler lip and bumper cover in place. Now we can focus on thebumper cover itself. You’ve removed most of the fasteners on the underside byunbolting the fender liners. However, there are still several in each corner ofthe bumper cover, at both the bottom, and one on the underside of the markerlight bracket. That particular bolt is a Phillips head screw. It is veryimportant to remember securing this point, as it holds the bumper cover inplace properly oriented the cover and keeping proper alignment of the cover toheadlight/side marker. It’s very easy to miss this screw until you’recompletely done installing the fender liners and you have these two screws (oneon each side) left over…Trust me, been there, done that… Don’t make thismistake. Once you have the covercompletely unbolted from the upper brackets leading the hood opening and allother areas around the bumper brackets, you can remove the bumper and exposethe radiator air ducts and bumper structure. To give you an idea of the timespent to this point, it took less than an hour to remove everything mentionedabove along with the two corner radiator air ducts. Removing the air ducts issimple, but you will need that flashlight listed above to see the TORX screwsin the front upper and lower corners of the air duct. Once you find them, it’ssimple to remove them and extract the ducts from the radiators. Then remove theupper bracket and lower bracket from around the center radiator. The radiatorshould remain supported by the hoses. You should have a clean bucket or catchpan handy to drain the coolant into. Pull the safety clip on the radiator drainand drain the radiator into the pan. Then remove both radiator hose clips atthe neck of the radiator hoses, and prepare to drain each side, one at a time.Once you have one side disconnected and drained, move to the other. I drained atotal of about a half a gallon of coolant, so don’t buy more than a gallon. *I did not take anypictures of the removal process, because it is covered both in the factoryservice manual link and online elsewhere. This is how it will lookwhen you have removed all the components above: Now, mounting all the new“stuff” isn’t really that hard… You need to swap in the new side radiator airducts, which isn’t hard. They bolt in exactly as the turbo units did… Nosurprises there. You’ll need to drill out the rivets in the center radiator airduct to replace the turbo version with the GT2 Version. Make sure to orient itproperly. Properly Oriented CenterAir duct: You will need to cut thenew GT2 Water line part numbers 996-106-625-75 and 996-106-621-75 to9 inches in length, measured from the end of the “collar” where the rubberstarts (at the radiator) to the end of the hose that connects to the hard waterpipe mounted on the car. The stock 996TT waterlines are much shorter than the required GT2 water lines: GT2 Waterline Partnumbers: Picture of the GT2Waterlines installed on the radiator: Slide the OEM stockSqueeze clamps on the lines about 3 inches up the length of the line to allowfor the hose to slide onto the pipe and then the clamp to slide up over the“flare” on the pipe (First pic is of driver side and second is passenger side): One of the things I’veread when researching some shop installs is that most shops had to relocate thehorns to a different location. I didn’t want that. Iwanted the horns to be where Porsche put them from the factory, and I didn’twant this conversion to look cobbled. Below is the horn bracket. Youwill have to remove it to get access to the passenger hose, but then can easilyre-install it in its rightful location: Before that I spent sometime with the grill vent making sure the duct and grill vent lined up: Parts that are required toorient the radiator properly. Notice the larger bolt andfastener. They are the GT2 units: In mounting the air guidenotice that the clip on the aluminum spacer sits with most of the spacer goingthrough the air duct. This clip keeps the proper distance betweenthe duct and the storage compartment: When installing the bumpercover, bolt the center grill in place on the bumper cover first, and installthe whole unit. Along with all headlight trim, and grill trim in place. I usedthe upper bolts on the vent to the retaining strip and then fit the bumperaround the air ducts and fit it to the mount holes at the side marker lights. Also, the GT2 Bumperstructure is the same part number as the Turbo. However, you needthe following parts in order to make the bumper structure clear the top of theradiator: More Pics of the instal: Here is where I mademistakes others shouldn’t make. Don’t buy all those water lines, like I did(God I hope Ryan can help me out with taking them back) but DO spend the moneyon the lower radiator mounts that bolt to the corner radiators. These mountswill make it so much easier for you to just bolt the stuff in. I spent about 6hours test fitting “stuff” because I didn’t buy the brackets. This could easilyhave been an 8-10 hour job. Instead it turned into 16 hours because I was busymessing with test fitting so much stuff. Part Numbers that you will need that Ididn't buy: 996-504-523-30 & 996-504-524-30. Notice the angle is off inthis pic: Also, because I bought mybumper cover from someone else who had decided to modify it by filling thebumper license plate holes in, I didn’t notice that the body shop made the areaa little too thick, causing interference with the bumper frame structure, causingme to inadvertently CRACK the paint/ bodywork around the license plate areawhen I was trying to fit the unit into place. My car is going to be re-paintedand wrapped within the next 6 to 12 months, so although it’s something thatkind of pisses me off, it isn’t the end of the world, and not very noticeableto anyone but me, so far. Thecoolant system was burped and all areas were checked for leaks BEFORE I boltedeverything back up cosmetically. Do not install the bumper cover until you’veconfirmed this. Procedures can be found in the Factory ServiceManual: Here is a pic of the left over water lines I didnot use. There are two LARGE water hardlines not in the picture: http://i145.photobucket.com/albums/r226/Mikelly_2006/GT2%20conversion/IMG_1558.jpg' alt='IMG_1558.jpg'> Here are shots of the final product: Of the parts I bought, and the parts I used, Ithink there is a difference of about $500 worth of water lines there. I have $3200 in the first 8 parts on thatlist, and they were shipped to me already painted Basalt Black. Of the other parts on that list, the airguides and fender liners each cost about $175 at the time of purchase. The rest of the bits and pieces cost roughly$1200. I did not price the radiatorbrackets that sit at the lower corners (mentioned above in discussing angleissues) but suspect they will be $400 each, per another members quote. And to add a little more insult to injury, I re-injuredmy formerly broken ankle yesterday stepping off my lift. The injured leg hadhit the edge of the lift, causing my ankle to roll, and forced me to put all myweight onto it… The audible “POP” and resulting pain made me fall to theground. I sat there trying to decide if I was going to cry like a little girl,or throw up like a big girl, but was so undecided that I just did nothing butsit and hold my ankle for a good 15 minutes… Ugh… Mike -
How to Install a New GT2 Style Front Bumper
Mikelly replied to vividracing's topic in 996 TT, 996 TT S, 996 GT2
I've since completed this project and will post a "Laymans" DIY for those who are interested. Mike -
http://www.renntrack.com/forums/showthread.php?1968-997SSK-in-996TT-and-other-models Mike
TT Rear Brake Pads/Clutch Accumulator
Mikelly replied to 911mike's topic in 996 TT, 996 TT S, 996 GT2
I have done so many of them on my lift, that I can do them in about 30-45 minutes normally... The key to making sure NOT to ruin the water lines is in my DIY elswhere here... Use a LARGE freezer baggie with the zip closure and make sure as you unscrew the unit that you keep the bag up over the whole of the unit and slave cylinder. I've done these for a number of members from sixspeeds and rennlist. Deckman, doing the accumilator is cake. Doing the slave cylincer is the painfull part of the job. Expect 4-5 hours at an indy. If you tackle this one yourself, the key is to lower the front trans mount a little (I loosened the front bolts until they only had about 1/4 inch left holting the trans in place) to give you access to the bolts that hold the slave in place. When you go to install the new unit, make sure the rod sits properly in the cup as you seat th unit and start the bolts into their threads on the case of the transmission. And to the other member above recommending the GT2 upgrade... This is not an "Easy" upgrade and is far more costly than just replacing the accumilator... Upgrading the GT2 bits alone is gonna run $1000, not to include labor, and I don't think you're gonna do this one on jackstands. The time to consider the GT2 hydraulic upgrade is when doing a clutch replacement while you have access to everything at the time. I've got the GT2 clutch hydraulic upgrade done on mine, and love it, but it is not simple to do and not something I'd recommend over the accumilator unless you have an upgraded clutch kit, normally required for upgraded horsepower. Mike -
Just installed a 997 shifter into my 996 Turbo MY04
Mikelly replied to aquinto's topic in 996 TT, 996 TT S, 996 GT2
I bought mine thru Suncoast... http://www.suncoastp...Code=996tttrans Just so there's no confusion... Here's the same part number in the 997.1 GT3 section... That's the 997SSK I got from them and installed. http://www.suncoastparts.com/product/X99742498300.html?Category_Code=997gt3 Mike -
So I went back this morning and checked the FSM and the Parts listing and confirmed the only part number differences were in the shift knobs. There is no difference that I can find in any of the standard vs. X50/ "S" models with regard to the shifter... I've had three of the units and can honestly say the 997SSK is the best I've had my hands on... Mike -
If you look in the DIY section, I believe we have pics in my DIY of the differences in all the shifters being discussed. Don't believe there is any difference in the X50 or "S" shifter and the non-X50/S shifter from the stock 996TT. As to the comments someone made about the 997GT3 shifter, know that it is basically the STOCK 997 Shifter's throw with the addition of the metal in the actuator. The 997SSK is a different shifter in that the throw is almost as short as that of the B&M without the notchy feel. Mike -
How about info on the parts required? I'm doing this with an OEM GT2 front bumper right now, and some info that readers should be aware of... The inner fender liners for the GT2 bumper aren't the same. Maybe Vivid's aftermarket unit doesn't require them, but the OEM unit does, and they are an integral part of the whole "aero" package... Also, the BELLOWS for the radiators don't line up with the openings in the corners. You'll need those as well. And that cool grill opening at the leading edge of the hood? If you want it to be functional, you'll have to get the proper radiator hoses, brackets, shims, and other bits in order to make it all work... Here is what I had to buy: 996-505-311-30-G2X Bumper Cover 996-505-563-30-01C Air Inlet 996-505-564-30-01C Air Inlet 996-505-561-30-01C Air Inlet 996-575-326-30 Bumper frame (front diffuser) 996-575-325-30 Bumper Air Duct 996-505-741-30-01C Bumper HID 996-505-742-30-01C Bumper HID 996-505-773-32 Spacer Panel 996-505-531-30 Retaining 996-575-321-30 Air Routing 996-575-322-30 Air Routing 996-504-195-30 Radiator Bracket (Upper) 996-504-679-31 Spacer Sleeve 996-504-413-30 Radiator Bracket (Lower) 996-575-141-30 Cooling Air Duct 996-504-123-90 Inner fender liner 996-504-124-90 inner Fender Liner Plus 20 part numbers for related water lines if you choose to keep it completely OEM. We talk in areas of "form" and "function" but if you study the reasons for the differences in design of the GT2 front bumper, and its related ducting, you'll get a better sense of why it's important to have it matched to the rear wing, but also a better understanding of WHY it's important to make that front center grill opening functional. The amount of downforce, where it is in relation to the front axle of the car, and moreso the ability to move stagnant air up and over the car is why you want that grill opening to do more than "look" functional... think of it the same as those openings behind the doors that feed your intercoolers... They're there ONLY because they must be. This is by no means to take away from what the boys at Vivid have posted. I'm just trying to bring to light the required parts list to make the bumper do as Porsche intended... otherwise you might was well be driving a Honda Civic with a big wing, fart-can, and cheap fiberglass bumper...NAWZ!!! Mike -
installed 5 bar fpr now car won't start?
Mikelly replied to fastlane's topic in 996 TT, 996 TT S, 996 GT2
Do you have a tune that requires a 5 bar FPR? Did a tuner suggest you upgrade to the 5 Bar? I only installed mine when I upgraded software from Upsolute to UMW and the tune, along with the turbos I am running, required more fuel. Otherwise the stock FPR is fine for most who aren't boosting more power via larger turbos. If your tune isn't setup for the 5Bar FPR, you're shoving to much fuel into the combustion chambers and flooding the plugs... Mike -
Any update on this? I ended up going with the taller gearing of the 997TT mainshaft and 1/2 gears... Went with steel syncros in 3-5 gears and all the rollpins (which is probably what came out by the way) are safety wired so none will every get loose and eat bits and pieces again. I also went with a Guards LSD while it was out, did the GT2 Slave Cylinder upgrade and had the CM clutch disc re-surfaced with Fibertuff material. Mike
Sorry to hear about the accident. I'd recommend talking to Marksky over on 6speedsonline. You'll probably get two of the same or BETTER quality for the price of one EVOMs brand... Mike
Frank, I understand well that everyone has a difference economic situation and that we all can't spend cash the way we would like. However, ignoring an oil or "other" leak could well lead to more expensive issues long term... This is "my world"... I do as much as I can myself to offset some of those expensive costs... Zero leaks is the only acceptable answer, period. Didn't come from the factory with "leaks" so in my book, zero leaks are the only answer... Mike
Couple of things here... First, no "leaks" are acceptable, ever. Get them addressed. Second, there are some expansion plugs in the motor... They leak coolant. That coolant mixes with grime and dirt, and looks a lot, like oil... Don't assume it's oil unless it is wet enough to tell the difference. Previous owner had my car into the shop a number of times over those plugs leaking, and coolant leaks... After I'd bought the car from the dealership I met the previous owner and he'd told me that they advised him to sell the car due to the leaks... Funny thing is, they fixed all of them, and I've not a had a single issue with ANY leaks in 3+ years of hard tracking and driving on the street. Also, My car has never used any oil between changes... During track season I typically see an oil change every other track weekend, but from the fall until the spring I don't change the oil at all and still don't see any oil consumption. I put on several thousand miles per year on the car, too! Mike
Your front diff and axles took a pretty bad beating, as did the transmission from all the shock- loading. I'd have the fluid changed in fron diff and rear transaxle. You "might" be ok as they don't run cars to redline during those tests. But it certainly took some life off the drivetrain. Sux man... Sorry to read this. Mike
Well I bought my 2001 used with 9100 miles on it. Since owning it the only things I've had "go out" from use are a MAFS, which I suspect was due to an overly oiled K&N filter... I bought my 996TT in Feb 2007 and have tracked it a LOT since then, and also used it as a daily driver when I want to commute into the Washington DC metro hell traffic that is the region I live just outside of. My 996TT has gone thru a clutch replacement that was brought about by power upgrades (UMW software to match the existing upgraded turbos) and the transmission has been upgraded to get rid of the damaged #1 & #2 syncros and #1 gear wear. I also got rid of the horrible Clutch hydraulics system that is LINKED to the powersteering system and uses a rather chostic fluid known as PENTOSIN CHF 11. This stuff is flamable at a very high flash point a few 996TTs have been destroyed due to leaks... The only complaints I've had with this car are as follows: Shift - The shifter sucks on these cars and the only real solution in my mind is the 997 SHORT SHIFT KIT upgrade, which can be had for about $430 thru Suncoast. Clutch Hydraulics - Vague pedal pressure means you aren't always sure that the car is in gear and you can't modulate the clutch. A quick scan of the boards will tell you that the accumilator and slave replacements are common... Every year there seems to be a rush of these threads in the fall and the spring. If you ever pull the transmission for anything, replace the system with the GT2 upgrade. Brakes - My Corvette had better brakes from "Stock" bits... The 996TT is a HEAVY car and without proper cooling and proper brake fluid (Don't mention ATE to me as it is NOT sufficient) will make an outting at a trackday more enjoyable... better pads (DON'T use PAGID ORANGES) will make the car perform even better. Suspension Adjustment - This car is limited in its adjustment. For such a great supercar value, you can't adjust the caster at all from the factory, and you can't adjust the camber as much as true track junkies need. If the car is lowered, you can get up to about -1.5 in the front and about -2.0 in the rear. At stock ride height, which is to tall for such a sexy car, you're going to be much more limited... maybe -1.0 in the front and -175 in the rear... Unfortunatelty the solution is GT3 Split Control arms with ajdustable thrust bushings up front and adjustable dogbones in the rear. The Toe adjusters also are known to slip in track conditions, so plan on better rear toe links as well... $2K in parts NOT including coil overs or swaybars... Mine has been a wonderful car that has provided much fun and excitement at the track, and much enjoyment on the street. The car gets attention everywhere, and on long road trips or stints on the highway Im' knocking down about 25-26mpg. I owe that to Kevin and his wonderful tuning at UMW. At the end of the day, it's a Porsche, and there truly is no substitute. Mike
NGK is concerned with selling plugs. They'll claim a lot. I'd not gamble with them, based solely on the time involved with swapping plugs on these cars... Bosch FR6 for mine, no question. Mike
Motor mounts could contribute to the "shock" feel, but if it is minimal, then I wouldn't worry about that. You're going to have to go back to Cargraphic to get matching cats. I don't see you getting something that will work from another vendor. I've had 5 different systems on my car and none of them were the same in shape/size. Mike
DIY Accumilator with bleed instructions DIY for Clutch Accumulator W/Pics... So After Gunther drove my car and stated "it feels just like when My accumulator went bad, you know the one YOU replaced?", I started thinking... Bet that thing went bad when it was backing out at the track last September. I've swapped these for several other 6speeders, and swapped my own, along with the slave (search here for that back last spring). So I called up Ryan at Suncoast, ordered an accumulator and a Mastercylinder and waited. They came in Author Mikelly Category TT/GT2 (996) - Common Fixes and Repairs Submitted 03/27/2010 04:17 AM
