X911CarreraX
Contact Methods
  • Website URL
    http://
  • ICQ
    Pleasanton
    99' 911 Carrera C2 Coupe
X911CarreraX's Achievements
  1. I had a similar problem when I had two different pairs of tires on the car (front tires were the same brand and the rear tires were another brand). My ABS was kicking on early, but with some decent amount of pressure, and it all went away when I got new tires that match the front set. Not sure if this applies to you, but something not associated with the ABS sensor could be at fault too.
  2. I saw that car pass me on 680 once, and it was loud!!!!!!!!
  3. reminds me of dirty wheels...
  4. tried it in my 99, doesnt work... still trying to figure out something else that would work
  5. tried it and i didnt get a beep:(
  6. Is there a way to make your car honk or make anykind of noise when you lock or unlock your car? the lights blink but thats it.. I always get to my car after going somewhere and realize i did not lock my door, so hopefully theres a way to make it sound when i lock, any ideas?
  7. you can try to put butterfly valves on ur exhaust, and you can open it at speeds above 5500,but thats manually open it...and im sure you dont want to manually open it at 5500 when ur racing. Maybe you can try to find some thing that will make it open at a certain time. kinda like the PSE..
  8. the dyno chart looks like it is done in paint aswell.
  9. I was wondering if the understeer for a stock 99 carrera is alot or alittle... I was going around 70-80mph accelerating on an on ramp corner and I was getting understeer. Wondering if it could be the wear on my front tires, but the tires seem to have some life on it. There Continentals and i have Michelin Pilots on the rear. So do the stock Carrera's have bad understeer? Or is it the tires?
  10. the car looks great, didnt know you can do that with 98's
  11. is the rattling only when you slow down, or is it there consatantly?
  12. so i can jsut buy the pads and install them... ? how ahrd is it to take off the side panels?
  13. i noticed that everytime i roll down my window, two grease circles appear on it. one towrds the front and one towards the rear. no idea what is happening. any ideas?
  14. i may consider...27k on car, is it going to be a even swap?
  15. 6 days for going 110?!!?! thats crazy, dont you serve maybe 1 day in jail here in CA.?
