contigo
Everything posted by contigo
  1. 2 sets for me , same car for a friend
  2. Add me I am contigo on both forums, I have a 2001 996tt
  3. I am doing the Evoms Gt2 kit next week , do I need to put the engine and gear box down to do the work or just by lowering it a little?
  4. Loren low cost for the 996TT? I dont care if I have to cut cables .....
  5. I had my ecu remapped, now with the gates (evoms) i was doing 1,1 boost and pulled them 2mm more and instead of seeing higher boost i dropped to 1,0 max boost
  6. Unless i'm missing something here, how is an intercooler going to give your more boost or spool up faster?? They are just what it says on the tin.......... a cooler. So an upgrade only will make the oil cooling more efficient etc, not improve your performance? If you run bigger turbo's you need better intercoolers to keep the oil temp around the turbo's within limits so you 'maintain' optimum performance and dont damage anything. But intercoolers alone wont give you more BHP?? AIR INTERCOOLERS, WHO IS TALKING ABOUT OIL INTERCOOLERS?????......
  7. Great!!! for that mounting what do you do? Any difference you can notice when you changed them? Earlier boost, more boost, etc?
  8. Great!!! for that fitting that didnt fit did you just change the clamp? Any difference you can notice when you changed them? Earlier boost, more boost, etc?
  9. Seems we are alone on this one and neither knows the answer, there are some 997TT new ones on e bay for $200 each
  10. Not here, the dealer here doesnt stock any parts here just filters, very bad service in our country from the PORSCHE REPRESENTATIVE
  11. All I have heard it is the same cores but no sure if the same cores as the GT2 996 and they make some changes probably on the ends, but heard also the hoses and everything on the 996TT will fit, want to know if they are an up grade or maybe just the same stuff
  12. So are they the same and they change refs nos?
  13. Try this http://www.cannell.co.uk/Manuals.htm
  14. I have Gemballa front bumper and I have 120mm, every 6 months I repaint the bumper, anyways apart from the bottom scrapes it starts to develop rock paint scrapes, Something I learned is part of owning this car
  15. Halloween boxter looks pretty nice
  16. Bought it also but after 1 month they didnt ship, I was sent the tracking nos yesterday, dont expect any problems, agree beats buying a new unit which was the only option ....
  17. Since you are moving on HP you will add more and more, to be safe go to the stage 3 kit, EVOMS, AWE, CLUTCHMASTERS, etc.
  18. I agree it is a disease and I dont know how to stop it, now going to the 700 HP mark (range)
  19. Does any one know if the intercoolers on the new 997TT are the same as the 996GT2? Or what are the differences if any?
  20. I have JURID 277 GG on my car and need to replace and cant find them anywhere, can anyone help. They are for 8 piston front Brembo brakes
  21. Can people chip in with information and recomendations of rear wings for 996TT, I am considering the Gemballa Large wing for my car
  22. Will play with the gates as you suggest, I also think that is the thing I have to look at , but my fear is with the new 75mm TB (maybe too much air???...), I think that is what I am missing to have the car perfect the low RMP high boost (in the 1,0 range), as soon as I have that solved I will try to push it up a little more like you have it in the 1,2 range I am sure in that range you must feel a big difference from 1,0. The problem is that I installed the gates and didnt leave enough lenght to pull it more so I have to take them out and leave more rod space for the screws in the setup, I am not paying attention to the mm setup but starting with the gates at zero and then moving little by little up in the setup (I think that is a better way to go, dont you?...)
  23. On my 996TT it shows that wait message with a timer that only moves when the switch is turned on, if you turn the car off the timer doesnt move and doesnt run out
  24. I have strut bars from EVO (great) both front and rear
  25. Go with the manual recomendation 2 mins at iddle
