Itzkirb
Everything posted by Itzkirb
  1. Mine is the same as Lorens also. I can see a line, not sure if I would call it a gap.
  2. I just pulled hard and mine came out.
  3. v8huntr, I know a member on this board that has H&R and 19's. His board name is sennasixty8, you might want to PM him.
  4. :rolleyes: Don, Right now I'm just dreaming... :rolleyes:
  5. well, if someone wants to buy it for a reasonable price I'm thinking of upgrading to a GT3 or Turbo :drive:
  6. or you could buy a seal gray '03...and I know who has one for sale...<wink> <wink> Check it out it's in the Garage Section... http://www.renntech.org/forums/index.php?s...e&CODE=12&CID=7
  7. I have a good C2 is you're interested? It's listed in the Garage section. It's very well cared for.
  8. I feel so Standard. I have Xenon-Evny
  9. Hardest part of the job is geting the toolkit out =)
  10. Mine is OEM and came out of Josh's Seal Gray GT2.
  11. Longhorn If you want to switch I have Stock and will trade you for your PSE!!
  12. Yes, the switch is the most expensive part, since it's a Porsche Item. The wiring and plugs you can get at any Radio Shack for under $20 I believe. The only reason I used 16gauge wire was I had some laying around. I'm sure you could use any guage cause if you look at factory wires they are pretty skinny.
  13. Robyn and I might try and swap one out this weekend to see if it works. She has Bi-Xenon and mine does not. Loren, do you know which wires (color) we need to use and not use? I don't want to blow anything up =) Thanks -Kirby
  14. Boca, let me know if you have any questions about anything.
  15. Just did mine http://www.renntech.org/forums/index.php?showtopic=574
  16. Also, you might want to double check that all the metal connectors are making contact. Sometimes when you remove the lighter unit and light the metal contact can bend.
  17. I didn't notice it was a glossy finish until you and someone else mentioned it. Now I have to go and order a Matte finish one. Crap!
  18. Now instead of having to reach down near my ankles it's handy on the center console. More info on the install can be found on the links below. http://hobbystage.net/porsche/itzkirb/ or http://www.renntech.org/forums/index.php?s...e&CODE=12&CID=7 (ditto more white space removed -- Loren)
  19. I Hardwired my Garage door opener. Very handy and gets rid of my big garage door opener. Looks very stock. More info on the install can be found on the links below. http://hobbystage.net/porsche/itzkirb/ or http://www.renntech.org/forums/index.php?s...e&CODE=12&CID=7 (edited out some of the white space -- Loren)
  20. Is there a Link or something to these Batwings? I want to order one also.
  21. Loren Sorry for posting twice, I wasn't sure which section it should go in. I actually found another solution to the wiring http://www.industryfigure.com/berkeley/Por...s/valentine.htm Thanks
