RFM
Everything posted by RFM
  1. Hi You need a PIWIS tester or similar tool too reset, at the same time give a look which code is still present, and try to fix it. Sorry for my poor English. Regards
  2. have a look at the release bearing, perhaps the problem is situated in the clutch.
  3. Hi Programme the settings of the car (country code etc....) by PIWIS tester,and a great chance that it works fine. Regards
  4. Hi Yes it is possible. Remove rear bumper,both coolers and heatshields. Succes
  5. http://www.europipe.be good sound, perfect fitting and good quality. Regards
  6. Remove airpump Remove attach Remove cover (not so easy as the left side) There are no recalls( in Europe ) part number changed several times.
  7. Hi a) most of the V8 engines have got this timing problem.It is adjustable,but commes back without fail. B) replace coils,clear codes. c) each time the battery was disconnected,this code appear.Drive a little bit and claer the code. It is not so bad as it looks . Regards
  8. There are more possibilitys by full turning, 1- low outside temp.and cold front tyres(scratching) normal 2- less of oil in the steering servo 3- faulty drive belt tensioner (both screaming) not normal.
  9. If your clutch is really hard to depress,the pressure plate (diapragm) comme to his end.This is not really a disc problem.Complete replacement is recommended.
  10. Attention,the switch is also a parameter for cars with TEMPOMAT. Problems will occure.
  11. Install new damper plates, 8 pieces and 2 diameters. Kind regards
  12. Looks like the idler pulley (#3) is not in line, starting from the front a- cover, b- idler, c- shim(approx. 4 mm.), d- spacer. Succes.
  13. Hi Some alternators are carry out with a " freewheel pulley", check for correct working. Regards
  14. Hi Replace the headlight switch.
  15. Hi For so far as i now, is the bearing not for sale as a single part, but as a part of the intermediate shaft. Removal of the bearing is not done without internal damage, timing chains ,oil pump drive, etc. Regards
  16. Hello Only some earlier Cayman S (MY 006 ) have got this problem. Boxster S recieved only from MY 007 the 3,4 l. engine, all with this problem fixed. The face lift is expected for MY 008 ( perchance with direct fuel injection ??? ) Best Regards.
  17. Hello, There is a possibility that the plastic protectors on both sides and in the middle, on the car bottom, contains gravel Regards RFM
  18. Hello The switch inside the lower rotationpoint of the carrier is probably faulty, no communication carrier - hatch. Success. Regards RFM
  19. Hello, The service interval counter in the instrument cluster is probably not reset by delivery at the client, ( new car ). PIWIS - instrument cluster - special functions -reset service interval. The dealer is able to see by using the PIWIS tester what's wrong and fix it ( message erased is too simple ) before the 24 month warranty ended. Regards RFM
