RFM
Everything posted by RFM
  1. Given the cranckshaft pulley (driver) is smaller in diameter, all other OEM pulleys, waterpump, alternator, steeringpump, etc. will rotate slower. This can cause all sort of problems at lower speeds as city traffic, idle, etc. These products are suitable for racing purpose where always high engine speeds are achieved, not for cars that are used on public roads.
  2. Leaking steering rack/pipes can show such symptoms, you will have to look more closely. A 996 Carrera use power steering fluid only for the steering rack, not fore brakes and clutch. Only the Turbo version uses the same system for clutch assist.
  3. Top up till the hot full level with the engine in hot condition and keep an eye on the fluid level for a while. Perhaps there were still airbubbles in the circuit, or there is a fluid leak somewhere, outwardly or inwardly (internal leak in one of the pumps or steering rack)
  4. The problem which arises with all-season tires is that the performance and handling of the car are not as good as summer tires at higher temps., and not as good as winter tires in winter conditions. The bottle is half full or half empty depending on your mindset, but never perfect. Just my opinion on that matter.
  5. Check the fuses-if OK check the microswitch-if OK check the retract motor for open circuit-if OK check the wiring for pos. and ground, the wiring may break inside the grommet on top of the tailgate door ones in a while. If everything is OK, a diagram is recommended to continue, a PIWIS in "fault find mode" is even better.
  6. Removing the alternator and throttle body are sufficient, then there is room to manipulate the two Torkx screws. Dont forget to disconnect the battery, and after assembly, relearning throttle body, windows, radio, etc.
  7. Older cars are not equipped with an electric soft close system, it depends on MY. You can check it by removing the trim around the lock catcher, you will see the electric motor than.
  8. Has a GTS turbo in Kenya?
  9. To start with, there are two different manufacturers: ZF and MB, yours should be a ZF. So you need the same brand Tiptronic, same type number (Carrera and Boxster are different given the 180° rotated installation of the powertrain) and same gear/transmission ratios. Tiptronic "S" or non "S" is not an issue, this only concerns a different control box and buttons. Hope it helps.
  10. The fan is located above the feet of the passenger (LHD) and is relatively easy to remove, just a few screws to remove and the fan slide out of the housing.
  11. There must be an intervention in the engine management as well, ignition timing, injection etc. Porsche does not permit such conversions, any kind of reponsibility shall cease.
  12. The rear side windows are not glued in, as the inner rubber seal is removed you will see that the window is attached, with screws, to a regulating system, sometimes the screws come loose with a creaking sound as result. Tighten the screws, in compliance with the rear side window up/down and in/out possition, and lubricate everything inclusive the seal with some silicone grease or spray. Then do a test drive related to the creaking and eventually wind noise. If the creaking still persist, it may be that one ore more weld points have come loose. That is more a bodyshop matter.
  13. As with all Porsche, use a PIWIS diagnostic device and leave, for this, a specific program run.
  14. Cd charger/player, control box towbar, etc. depending MY - country and code #.
  15. You can not empty the torque converter without removing the Tiptronic, the only way to empty the converter half way without removing the Tiptronic, is removing the valve block and let the Tiptronic a full night to drain. It would be a crazy idea and a big risc to do that only for an oil change IMHO.
  16. If the accident happened while driving is the risk of damage much smaller. However, it does not exclude asking the seller some warranty.
  17. Glad it is resolved, pay attention to the wiring nex time, the colours, and Hal sensors have 3 wires, Inductive sensors have only 2 wires. Are there no error codes appeared?
  18. When the hit happened with the car parked and in gear, it may be that the gearbox is damaged in the longer term, although it shifts fine at standstill and engine not running.
  19. First try to wax/polishing the windows, it should already bring much improvement.
  20. Thank you for the explanation, other members can benefit from it.
  21. Correction, it should be "clamped". It would also be useful to identify the cause of the excess oil.
  22. Remove: pull the wire clip backwards pull the pressure pipe out of the connector remove O-ring wipe off the oil residues and clean up replace O-ring install the pipe and clip It is normal that some play is observable, the pipe is claped by the pressure, same system is used on the cooling water hoses and radiator connections on later 996.
  23. Read this http://www.renntech.org/forums/topic/29137-996-ignition-switch-replace-just-the-switch-with-pictures/page-2?hl=%2Bignition+%2Bswitch+%2Bfailure#entry235910 I suspect the 365.00 dollar is the price for a complete switch and lock mecanism, you only need the electric part of it. It may be that AUDI is stamped on, this switch is used on multiple brands and types of VAG group.
  24. It could be that R stands for replacement (3 party) and G for genuine (Original) given the price difference, albeit minimal. You can Always e-mail the supplier and ask for an explanation.
  25. Problem with the electrical part of the ignition switch seems plausible, this does happen regularly with ignition switches between MY 1996 and 2005. A replacement is the solution, there is definitely a DIY here, use the search button on top of the page.
