RFM
Everything posted by RFM
  1. The clutch hydraulic system on a TT is filled up with PENTOSIN hydraulic fluid, look out with that. The canister is located under the trim on the left of the battery. If a bleeding of the clutch system is not necessary, let it like it is.
  2. You cant, the poly-V belt is equipped with a automatic tightener. You can replace the belt and the rollers in case of noise, check the alternator, water pump and steering servo pump as well.
  3. The CD player is defective, there are some options anyway: OPC - new or rebuild unit. Harmann-Becker - repair.
  4. All 987 have a cabin filter and you can use the activated charcoal filter as well, they have the same size. The filter is located under the trim, for LHD on the right side ( battery area ) well covered behind a flap. Perhaps for RHD on the opposite side.
  5. The headlights and direction indicators are controlled by control boxes, they have no fuses. Check fuse 3 on row C ( light switch ) to start with, if you cant find something than you need the PIWIS tester to find out.
  6. Strange, this kind of sensor is not in direct contact with the cooling water, correct me if i'm wrong.
  7. Strange that the 997 Turbo keeps going with the old Tiptronic.
  8. 17" is possible if the car have got no brake upgrade! I have no idea concerning the homologation in the US.
  9. Pull off the cloth hanger and remove the screw, pull off the trim and pull backwards. The amplifier is on the right A pillar.
  10. The antenna amplifier is located behind the trim on the A-pillars.
  11. Cleaning the radiators ( remove the front bumper ) is discussed many times before here on the forum, do a search. There is no oil cooler on the front, only cooling water and AC condensers.
  12. Under normal conditions 2012/2013 as usual. The 997/2 generation is more than a face lift, complete new designed engine without intermediate shaft ( good news for the owners - bad news for the forums ), crankshaft bearings placed more at both ends ( makes the shaft stiffer and discharge the RMS ) redesigned timing chain, direct fuel injection and a lot more. Also a new double clutch gearbox which replace the Tiptronic. The car drives really fantastic.
  13. Don't forget to check the piping under the oil filter area on top of the engine for cooling water residues too. The cooling water drips on the flat top side of the hot engine and evaporate, there are no drips on the floor in this case.
  14. I cant help you out i'm afraid, ox. sensors in the middle of the cat. are new to me. Are you sure of this ?
  15. Disconnect the air tube under the dash on the center, if air comes out the center module, the obstruction is situated in the air tube or the vent. orifice.
  16. Before ordering the rear door struts ( 2x ) check the door glass struts ( the smallest ) first, they have to lift the glass perfect. The big door struts are not able to lift up the door "as new", they needs the help from the glass struts as well.
  17. Correct, the engine is made of light alloy. The product prevents corrosion for some time.
  18. Grommet front middle radiator fixation.
  19. Only H3 55W bulb is recommended, 100W is too hot for the unit ( melting ) and the control box will give you fault codes on the display as well.
  20. 97boxsterred I did a search concerning your problem, try this: remove the cover on top of the engine - on the left side in the intake manifold sits a roll ( cylinder ), the roll is not visible, the roll is attached to a vacuum control element at the left rear side of the manifold, you can see it with a mirror. Check for "play" - grab the roll connection with one hand to eleminate the "play" while someone else start the engine - check for difference in noise. Please rapport back.
  21. Warranty = exchange = rebuild = same engine as the defective one. Only if you order ( and pay ) a new engine you got the choice.
  22. It can be done as you describes if you have any experience, it is easier to remove the strut so that you have a overview to the parts etc. especially for DIY job IMHO. Start to loose the nut partial on top of the strut to have a idea what's coming, i'm pretty sure the nut is rusty and difficult to remove with the UK rainy conditions.
  23. Take a look if the brake booster inside is free of water, when the drains are clogged up in the battery area rain and wash water will easily penetrate in the booster with a sticking brake pedal as result. Do a search, this problem is already discussed before.
  24. The side flap is the cause of your problem, there is something wrong with the mecanism whitch is not as simple as that, let the dealer check what exactly is wrong.
