RFM
RFM last won the day on August 19 2024
RFM had the most liked content!
About RFM
  • Birthday 09/04/1948
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    Motorcycle racing
    Belgium - Passendale - Flanders Fields
    987 Tip-Tronic ( wife's car )
    Audi A1 1.4 S-Tronic 185HP
  • Future cars
    Since my age, probably a wheelchair.
    986 ( wife's car )
6,289 profile views
RFM's Achievements
Community Answers
  1. Vibration/resonance dampers together with the bevelled edges of the brake lining, squeaking noises are prevented.
  2. Isn't the system programmed for Km/h instead of miles?
  3. This is a cooling water channel, the cover is secured with four bolts. The metal seal between housing and cover is leaking and needs to be replaced, this occurs regularly. The work is easy to do, drain cooling water, clean the edges of the housing and cover, replace the metal seal, refill cooling water. Please note, to avoid filling and venting problems cooling water must be refilled with a vacuum device, this is very important to avoid an overheated and therefore defected engine.
  4. I looked in to my notes regarding 996/986, ABS/TC is a combi system. Perform a throttle valve cleaning inclusief the electric connector and check the wiring, it may sound weird but the throttle body is part of the TC system and too much resistance mechanical/electrical could cause such a problem. Let us know your findings.
  5. 035 amp is way too much, 0035 amp looks better with the system in sleep mode. So there is a consumer/control box somewhere that does not go into sleep mode or wakes up now and then. This will probably the cause of the ABS/TC problem.
  6. It looks like cooling water loss, there must been a big leak in the circuit. Low oil level is separate from this but must be brought up to level asap.
  7. You need a PIWIS diagnostic device to see which/when modules are being woken up, possibly also to detect CAN-BUS errors.
  8. If the car has a Tiptronic gearbox, an internal eak from the cooler can cause this phenomenon. Check the ATF oil for intermix with cooling water, the gearbox can be destroyed in a short time.
  9. These flaps are on the hinge mechanism,left and right,of the clamshell to protect the convertible top from friction damage when driving top down.
  10. Take the car and all associated keys to a Porsche dealer, he can synchronize them with the help of a PIWIS diagnostic device.
  11. Maybe a small drop of oil on the hinges and pivots will help.
  12. You should try driving with a conventional oil pressure gauge connected and see what the readings are. From this you can determine whether there is still a fault in the pump or elsewhere.
  13. Be aware that the remonte controled central locking system only works during approx. 5 days, car parked and nog used. After that time, the door must be opende manualy with the key to het the remonte control working again.
  14. Try to bring it back and use Mann for all filters, great quality and always fitting.
