sentipede
705 profile views
sentipede's Achievements
  1. Just noticed that both the bulbs above my rear license plate are out. Was looking to replace with PIAA LED , will I need the PIAA T-6 or T-10 dome light bulbs?
  2. OK, Well, I finally got around to picking up some Porsche coolant, and just filled it up. The coolant that was already in there looked yellow. This Porsche coolant that I purchased was pink even after the 50/50 mix. I added it and the light is off, is there any reason why the original coolant was yellow? Thanks!
  3. On a couple of occasions recently, shortly after start up, the red light at the end of the temperature gauge has started to blink red. When I turned the car off and restarted it, it seems to reset and go away. Is it possible that I am low on coolant? The car has about 24K miles, and was serviced 2K miles ago...no leaks. If I just need more coolant, what kind/brand etc...and how much should I use? Thanks in advance!
  4. I just ordered a set of sport seats with plastic backs. I wanted to see if I could do two things: 1) Paint the seatbacks - how do they disassemble? 2) Convert to full power - I currently have supple full leather seats, the new sport seats have power backs and manual seat, can I some how retrofit the power front/back mechanism? Thanks in advance!! :help:
  5. Alright, well it snowed pretty badly in Chicago last weekend and my car got covered in salt. The next day I drove my car straight to the car wash about 5 blocks away, washed it and drove it straight home and parked it. Well, when I hopped in my car today...4 days later...and disengaged the park brake I had to give the car some gas before the brakes broke loose of the rust...ughh. Anyhow, the first few brakes were very weak and had a scratching noise. As I kept driving they started to get better, but were still making a noise. Anyhow, I drove around for a few blocks and decided to park the car. Will this noise eventually go away or did I cause any permanent damage to the brakes? Thanks in advance... joe
  6. Thanks guys...worked like a charm!
  7. How do I successfully remove this piece without scratching the leather dash or the finish on the piece? Thanks in advance....
  8. Looks great, I did the same on my coupe... Are the exhaust tips those from a C4S or TT?
  9. Is there a difference between the exhaust tips on a C4S and those on the TT? Are they interchangeable? Thanks, Joe
  10. Thanks for the help. So I assume that these are the ones with the wider bypass pipes and the throatier sound. I was deciding between the fabspeeds and these (used 5,000 miles @ $950) for my 2000 996 C4. I appreciate all the input.
  11. So, are these the most advanced version of the PSE for the 996 or did they release a better, more improved set? I know there was the first one specifically designed for the 3.4, and then a later version which was built for the 3.6 but had the capability of being installed on a 3.4... Thanks again!
  12. What model PSE contains the following mufflers on the PSE? Are these the 3.4 or 3.6 versions? 996.111.385.01 996.111.384.01 Thanks in Advance!
