tomdeg
Everything posted by tomdeg
  1. Demosan, Thanks for the link, search is your friend, as are our fourm bretheren. wross, Yep, they have RoW for coupes and cabs.
  2. Hi All, I just installed the ROW M030 suspension on my 2001 C2 Cab. I remember seeing alignment specs before but can't seem to find them anymore. I want to be able to give the shop the proper specs rather than relying on them to have it. Thanks Tom 2001 C2 Cab 6spd
  3. Springs are as follows; Ft - green on top, green/red on bottow Rr - green on top, green/yellow on bottom How can I tell about the rear springs from the vin? is it in the PET or do I need to contact a dealer? What about the bump stops?
  4. Yes, just purchased from private party, still in plastic bags, never installed. my vin is WPOCA29931S65XXX I'm confused about tha compensation plates, which ones do I need? Also, I didn't get new bump stops, do I need new ones or can I reuse? Thanks for all the help
  5. sorry, I meant compensation PLATES. BTW all the other components seem correct; Front springs - green/red Front shocks - 996 343 041 16 Front stabilizer - 996 343 701 04 Rear shocks - 996 333 051 13
  6. Loren, My kit that I bought has the rear springs with pn 996 333 531 13 with a green dab on top and green/yellow on bottom. Also the rear stabilizer is pn 996 333 701 25. I'm stressin' out. Are these correct for a '01 C2 Cab 6/spd? Are the compensator rings supposed to come with the set? Thanks, Tom
  7. Perfect! Thank you.
  8. Thanks Loren. How about ROW?
  9. Is there a way to tell if suspension components are M030 by looking at individual part #'s and paint dabs? I have a 2001 C2 cab w/6 speed. Thanks Tom
  10. I just recently replaced mine also @ 30k. I bought them from these guys: http://replacement.autopartswarehouse.com/...%20Plug&dp=true
  11. Here's one http://forums.rennlist.com/rennforu...ad.php?t=216715
  12. Loren, Can you show a pix and part # for the blue tool? Thanks Tom
  13. I bought a 2002 and up PSE switch for my 2001 Cab and sprayed it with clear lacquer. It matches the other switches perfectly. Tom
  14. So is the 996 613 988 10 A05 actually the correct part #?
  15. Which part # did you order? I'm in the same situation. I ordered mine per the shop manual listing (996 613 988 10 A05) for left side of radio and what came was one for the right side of radio. The dealership is reordering the other one.
  16. Awesome. Thanks Toolpants, exactly the answer I was looking for. Tom
  17. But will they peel back on?
  18. I recently purchased a set of Techart silver faces. If I switch them out and later change my mind, can I swap them back to the originals? Loren... Toolpants.....? Thanks in advance. Tom
  19. I'm trying to replace one of these vacuum actuators on my 996. If you don't want the quiet feature, you don't need these. If anybody doesn't want the quiet feature and would like to help a fellow p-car owner out, I could send mine for trade. It's the part that bolts on and includes the rod. :D :D Tom
  20. Does anybody out there (Loren, Tool Pants) have the instructions for installing the electronics for the PSE. Are the the electronics kits for the early (3.4L) and late (3.6L) the same? Thanks, Tom
  21. Hello All, Does anyone know if it's possible to replace the vacuum actuator on the PSE? Thanks, Tom
  22. Just put mine in the other night. OMG what a difference! It makes the car feel so much tighter. I installed mine the same way, left the cables in place, flipped the tower on it's side, pulled off the coupling, new shifter in, snappped the coupling back on...viola.
  23. I am interested in this as well. I recently purchased a B&M shifter an would like to adjust the cables perfectly before installing it. How does the dealer adjust the cables on a car that came with the SSK?
