Gundo
About Gundo
  • Birthday 10/04/1968
Contact Methods
  • Website URL
    http://
  • ICQ
    Newtown, CT
    '06 997 S Cab
    '07 GMC Denali
    '07 Audi A4 2.0
    '02 Volvo Cross Country
    '00 Boxster S
    '97 Boxster
    '86 944
    '86 944 Turbo
2,495 profile views
Gundo's Achievements
  1. From everything I’ve seen, there is no difference internally between the mufflers. The only difference is the outlet where the visible exhaust tips are bolted on. We can speculate as to why they are different sizes - common guess is you can’t easily swap the tips without some modification. I have confirmed though, that S tips slide right on to the Non-S muffler. Gundo Now what is Gundo up to ???? Nick: Whatever it is, I'm sure it's going to sound awesome! Regards, Maurice.
  2. Here is a great write-up to consider when doing the install. This is a nice addition to the TSB that Loren mentions above. http://www.planetporsche.net/reviews/showp...ct=99&cat=5 This should take you 45minutes to 2.5 hours based on how familiar you are with the vehicle but as Loren mentioned it is not a difficult process at all. I have seen the TSBs and used them myself to install the changer, took me 30 minutes. Sam
  3. Amazing that this happened, and I'm very sorry to hear about it. This is a truly unfortunate case of PCNA ignorance. they ignored your claim, they didn't do anything about it, and waited for your engine to self destruct. When you took to dealer, was it running? Would it run at all? were you really burning 1 qt / 100 miles?? I had a very severe oil consumption issue (1qt / 700 miles) that has since abated to 1 qt / 3,000 miles and I'm at 15k miles. Again, sorry to hear about it. I know exactly how you feel! The clutch stuff is really BS, as the clutch in my loaner '08 Cayman S (also with a dual mass flywheel) is great...no chatter, 0! I hope to find out about my car on Monday and will keep you guys posted. If Porsche does not do the right thing it may very well be my last...
  4. this is step 14 and 15:
  5. this is step 7 to 13: step 7 step 8 step 9 step 10 step 11 step 12 step 13
  6. Hi - got some great painted parts from bumperplugs that I wanted to install, but couldn't find the documentation to remove the door panels for a 997. the 987 instructions are close, but different enough to cause a problem if you pry where you shouldn't. So here we go, I tried to document with enough pictures for you to do by yourself. As always, be careful and take precautions when working on your car and around airbags. Gundo PET Diagram of door panel: step 1 step 2 step 3 step 4 step 5 step 6 step 7
  7. 997 Door Panel Removal Hi - got some great painted parts from bumperplugs that I wanted to install, but couldn't find the documentation to remove the door panels for a 997. the 987 instructions are close, but different enough to cause a problem if you pry where you shouldn't. So here we go, I tried to document with enough pictures for you to do by yourself. As always, be careful and take precautions when working on your car and around airbags. Gundo PET Diagram of door panel: step 1 step 2 step 3 st Author Gundo Category Carrera (997-1) - Mods Submitted 06/22/2009 02:42 PM
  8. Many thanks Loren.
  9. Hi Loren, Need your help - are the part numbers different for 997 and 997 S? also, what are the part numbers? Thanks!
  10. What a fantastic photo! the difference is amazing. I'm having X51 headers and AWE 200 cell cats + softtronic installed tuesday and can't wait! Thanks for the photo and driver reports
  11. The picture here is mine, from when I had the pictured bypass pipe welded in between the inlet and outlet on my standard 997S exhaust cans. Cost me $175 to have done and sounds absolutely awesome - hard to discern from the OEM PSE that costs $2000. Cheers, Gundo Here is a tip for you..... You can use your org. muffler and do a simple mod like this and it will only costs you about $400 to have a great sprot engine sound! I've seen people on the forums that indicate this mod can be done for under $200 by most reputable exhaust shops.
  12. As always - thanks Loren! Have access tp a PIWIS, so maybe we'll fool around with this one a bit. Cheers
  13. HI Loren, I've got a 2006 997 S without TPMS. I've seen several posts that it cannot be retrofit on my car. I would love to know if you can figure out the part number for the computer module that receives the signals from the wheels - it must be possible to update my car. Especially because the wheels I just bought have the sensors built-in already. THanks, Gundo
