unklekraker
Contact Methods
  • Website URL
    http://
    San Jose, CA.
    1999 Porsche Boxster, Arena Red (Date Car for my wifey)
    2004 Mercedes Benz C230 Kompressor Coupe (D/D)
  • Future cars
    1988 930 Slant Nose
    1997 993 Cab Tip
    1993 Ford Bronco w/ 4" body lift kit (my toy)
    2000 Dodge Ram 1500 4x4 Long bed (to pull my toy)
    1997 Chevy Suburban 1500 4x4 (family hauler)
    1997 Jeep Grand Cherokee 4x4 (trashed 4 wheelin in the snow)
unklekraker's Achievements
  1. Fix and done! Thanks TI, Loren and other members who chimed in for the instruction and diagram. @ 6 am this morning, I'm in the garage tinkering with the wiper arm and following the instruction I got from the other forum. Now everything is working...took me only 15 mins :cheers: In case one of you run into this situation here's what the member told me: Use something like a very small flathead screwdriver blade to pop/pry off the black cap that covers the wiper spindle. There's a slot on one edge where you can insert it. You will see a hex nut that secures the wiper arm to the rotating spindle. If it has backed off so far that the arm is not grabbing the splines, I suppose it would not rotate. If you are lucky, that may be all that is wrong, and you just need to re-seat the arm on the spindle and tighten the nut down. I think you need a 13mm socket.
  2. Yah...when I pusjh it, it catch up. I will follow the diagram and will post the result later on. Thanks guys!
  3. Thank you very much, Loren. I appreciate the diagram :-)
  4. Hi All, My wiper arm on the driver side is loose and only the passenger side is moving. Is there a thread for this issue? If there's none, I would really appreciate it if someone could chime in on how to tighten it and what told do I need. Thank You very much in advanced,
  5. YES...it works....thanks Loren :-)
  6. I know I've asked this before but my car got repainted and I lost the paper where I put the code :-( Loren, can I get the radio code again, please :-) SN# X5013597 type 4462 CDP2065 Thanks!
  7. Try 0111 or 0109 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hi Loren, both numbers didn't work :-( PLEASE read the FAQ. cool..will play with the numbers today.
  8. Try 0111 or 0109 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hi Loren, both numbers didn't work :-(
  9. Thank you very much, Loren! I'll read the FAQ first and try it out :-) Try 0111 or 0109 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  10. I replaced my 7 yr. old battery and it's running now but my radio is asking for the code. Can someone help me, pretty please. also need to know how to enter the code :-( Becker 1 CDR 220 4462 SN# X5013597 48/98 CDP - 2065 :renntech:
  11. T/P and Henry...my front trunk latch release is sticky, can I bring it there and see if it could be fix first before I order the parts or is anyone out there would happen to have an extra front latch release that would like to sell? Also my airbag light is on :(
  12. when I did change my headlight unit this happen to me and it took me a while to figure it out that when you turn all the way, it will lock again and it cost me a tool w/c is $20 @ dealer and found out that I could just use a reg. 5mm hex key :(
  13. A 99' Boxster S? are you sure it's an S? I thought they start the upgrade on 2000 and up....
  14. coo...i'll see you guy's then :) BTW...it's Gerry!
  15. will it be okay to go, just to watch and learn and probably ask some few pointers? and also to meet local Boxster owners :)
