Hugomcff
    Portugal
    1998 porche boxster 986 2.5 manual
Hugomcff's Achievements
  1. Porche boxster 986 2.5 manual from 1998 not starting. Car cranks but won't start. Already replaced: -Fuel filter -Crank position sensor -Ignition Switch -Fuel pressure regulator Can't even smell fuel from the exhaust. Have almost 4bar of fuel pressure. If I spray some starter fluid the car works fine. Need help
  2. Ofc not. I have drained the old fuel. Put 20L of fresh gas and changed the fuel filter
  3. Hello guys! I have bought a boxster that as been sitting around 5 years. I rotate the key, all the lights light up. It cranks but wont start. I have like 3.8bar of fuel pressure. If I put some starter fluid the car fires right up (i have spark). It seems like the injectors won't open. Immobilizer seems ok since the car cranks (also removed the module from under the seat and cleaned all up, it was not showing any sign of corrosion). I can hear the fuel pump working when I jump it. Already replaced the fuel pump relay and the ignition switch. In the diagnostic tool the car cranks at about 150rpm, is that normal? Also, im getting a value of -40ºC on IAT (intake air temperature). Vídeo WhatsApp 2025-03-02 às 00.12.37_6c29f9e5 (2).mp4
