Rob Lowry
Everything posted by Rob Lowry
  1. For those who have a CTEK or similar battery maintainer, did you permanently mount the eyelet connectors and if so, where? I'm thinking of mounting to the jump points under the hood / bonnet. The negative terminal may need some investigation, as it's quite a distance from the positive terminal (will the wires reach) and at a glance it didn't seem there was a point on the negative terminal for me to attach the eyelet ... maybe the negative point can be unscrewed and then screwed back down on top of the eyelet? Interested in your experience. Rob
  2. Thanks JFP. I hadn't seen Odyssey before, and have started doing some googling ... Any strong opinion on the Interstate brand available at Costco? I see they have a "superior AGAM", 'cause nobody wants an "inferior AGM" Their battery is 900CCA and 95ah ... H8. While I do a lot of Costco purchasing, I've never done automotive there ... bakery on the other hand. Roob
  3. Can anybody recommend a high quality, non-Porsche Dealership mechanic for my Panamera GTS in the Atlanta, Georgia area? Thanks Rob
  4. I'm nearing the point of needing to replace the battery in my Panamera GTS. Various threads I've read fall into one of two camps: ---Optima Yellow Top and Bosch are the best, and Varta is OEM ... can't go wrong choosing one of these ---An AGM battery, is an AGM battery and don't waste your money on a label What's your experience / recommendation? Thanks Rob
