Paulo Rebordão
Everything posted by Paulo Rebordão
  1. Trying to fix some coolant issues on my 03' Cayenne S. Can anyone tell where one of the lines that exit the oil heat exchanger goes to ? I mean the line that has a split going into the generator. Thanks
  2. I don't have much hope... but anyone has and can provide the Workshop manual for MY03 ? Thanks
  3. Days ago, a few hours after parking the car after a long drive, I see big coolant puddle around the front right wheel. I checked the level and it was more or less where it was before. Since then no more puddles appeared and temperature remain normal. Question: is there some relief exit on the coolant reservoir for when you fill it too much ?
  4. I just did that. Cleared the fault but it appeared immediately after. Fuse is ok (5A is just that ?) Other thing I tried was to remove the oil cap while idling. Idle changed audibly and became a bit lumpy... Is it normal ? Thanks
  5. I have an 03' CayenneS with about 200.000Km Yesterday doing a check with my new Foxwell NT530 scanner, I got a code 1182, which seems to indicate an issue with the PCV... Could there be another source for that error ? I can't feel nothing wrong with how it runs / drives... And BTW where is that thing located ?
