Paulo Rebordão
    Lisbon, Portugal
    2003 Cayenne S
    1974 911S Targa
Paulo Rebordão's Achievements
  1. That table doesn't look right. According to it, as minimum temperatures decrease, you should add less antifreeze???
  2. Which is the correct coolant to use ? And should be used pure or on a 50:50 mix ?
  3. I'm trying to find a fault in the wiring and would like to remove the trunk / filler flap buttons from the left door pocket... Any ideas ? Thanks
  4. I checked the fuses again, and the slot for fuse 50 in the left side is empty... User manual has a blank entry for it too. Are you sure is 50 ? And what should be the amperage ?
  5. I measured the resistance of the heater and got 35 ohms. Looks normal ? Anyway, if malfunctioning what would be the implications ?
  6. Thanks Loren The fuse was checked already. But where is this heater located after all?
  7. Cayenne S '03 Where is that and what's the possible cause ? Any help appreciated. Thx
  8. Trying to fix some coolant issues on my 03' Cayenne S. Can anyone tell where one of the lines that exit the oil heat exchanger goes to ? I mean the line that has a split going into the generator. Thanks
  9. I don't have much hope... but anyone has and can provide the Workshop manual for MY03 ? Thanks
  10. Days ago, a few hours after parking the car after a long drive, I see big coolant puddle around the front right wheel. I checked the level and it was more or less where it was before. Since then no more puddles appeared and temperature remain normal. Question: is there some relief exit on the coolant reservoir for when you fill it too much ?
  11. I just did that. Cleared the fault but it appeared immediately after. Fuse is ok (5A is just that ?) Other thing I tried was to remove the oil cap while idling. Idle changed audibly and became a bit lumpy... Is it normal ? Thanks
