Tara Black
Everything posted by Tara Black
  1. Hi! I have the same issue going on with my overhead lights. The footwell lights are working fine , and the center front overhead lights were working as well, but the side overhead lights above the back seat weren’t working and neither were the vanity lights on the visors, well I changed some fuses and now my center front overheads have gone out . The overhead in the luggage compartment are still working as well. Did you find out if there’s a special fuse or wiring diagram for the 2006 ? Thanks in advance! Update:: I changed that 5 amp fuse to the #27 spot that is supposed to be empty as per every diagram I’ve looked at and you’re absolutely right! They’re working again! Thanks so much! Still my side overheads above the back seat aren’t working and neither are my vanity lights. But I had a new headliner installed and I believe the wiring wasn’t reconnected after the installation. So I’m going to check that and hopefully that works. If not next I will check bulbs I suppose!
