Autonumen yang
Everything posted by Autonumen yang
  1. Hi everyone, I’ve just spent the last four years meticulously rebuilding my 1999 Porsche 996 C4 with a 3.4 engine, and while I’m thrilled with the progress, I’ve encountered a few issues that need addressing. After going through the manual, it seems that I need to perform a couple of essential tasks that can only be executed using the Porsche System Tester 2, commonly known as PIWIS. Specifically, I need to zero the steering angle sensor and activate the booster pump to bleed the ABS system. I’m considering purchasing a PIWIS system, but I wanted to check if anyone here has experience with this equipment and if it’s worth the investment. Alternatively, does anyone know of a workaround to accomplish these resets without needing the PIWIS?
  2. Using a PIWIS 3 diagnostic tool to troubleshoot a non-running Porsche 996 can significantly streamline the diagnostic process. The PIWIS 3 is specifically designed for Porsche vehicles, providing access to comprehensive diagnostic functions, including reading fault codes, monitoring live data, and performing system tests. When diagnosing a non-running 996, the first step is to connect the PIWIS 3 to the vehicle's OBD-II port, which allows the tool to communicate with the car's various control units. By scanning for fault codes, the technician can quickly identify any stored issues that may be causing the engine to fail to start. Furthermore, the PIWIS 3 enables the user to check crucial parameters, such as fuel pressure, ignition timing, and sensor inputs, to pinpoint the root cause of the problem. Overall, utilizing a PIWIS 3 not only enhances the accuracy of the diagnosis but also helps in efficiently addressing the underlying issues, ultimately leading to a timely and effective repair.
  3. Using the PIWIS 3 diagnostic tool can effectively solve the problem of a non-running 996. First, by connecting to the vehicle's diagnostic interface, PIWIS 3 can quickly read the vehicle's fault codes and real-time data to help technicians accurately identify the problem. Then, the system provides a detailed troubleshooting guide to assist maintenance personnel in step-by-step checking of key components such as the electrical system and transmission system. Through this efficient diagnostic process, maintenance time can be greatly reduced and the reliability and safety of the vehicle can be improved. PIWIS 3 can program the key.
  4. The PIWIS (Porsche Integrated Workshop Information System) is an essential tool for technicians working on Porsche vehicles, providing advanced diagnostic and programming capabilities. With the introduction of PIWIS 4, many advancements have been made over its predecessor, PIWIS 3. This article explores the key differences between these two systems, highlighting their respective functionalities, compatibility, and overall performance. Overall Advancements PIWIS 4 signifies a considerable leap forward from PIWIS 3, boasting improved functionality, enhanced compatibility, and upgraded security features. One of the most notable advancements is its support for electric vehicles, showcasing Porsche's dedication to alternative propulsion technologies. This shift reflects not only a response to market trends but also a commitment to sustainability. While PIWIS 3 was a reliable diagnostic tool for various Porsche models, PIWIS 4 elevates the standard with a variety of new features. Notably, it incorporates SFD (Security Functionality Device) diagnostic protection technology, which ensures both efficiency and security during vehicle servicing and maintenance procedures. Advanced Diagnostics and Programming Both PIWIS 3 and PIWIS 4 provide advanced diagnostic capabilities, enabling technicians to interface with Porsche vehicles, retrieve diagnostic trouble codes (DTCs), view live data, perform component tests, and conduct programming tasks. However, PIWIS 4 is designed with potentially enhanced features that ensure improved compatibility with the latest Porsche models and their sophisticated electronic architectures. Wireless Connectivity Options When it comes to connectivity, PIWIS 3 offers limited wireless options, which can restrict the flexibility of technicians during diagnostic and programming tasks. In contrast, PIWIS 4 is expected to feature expanded wireless connectivity options, allowing for greater convenience and mobility during service operations. This enhancement not only streamlines the workflow but also improves overall efficiency. Vehicle Model Compatibility PIWIS 3 is compatible with a wide range of Porsche models, covering both older and newer vehicles. However, PIWIS 4 is anticipated to provide broader compatibility with the latest 2024 Porsche models, ensuring that technicians can access enhanced diagnostic capabilities across an even wider array of vehicles. This extended coverage is crucial for keeping up with the evolving automotive landscape. Performance and Speed As the latest generation, PIWIS 4 is expected to deliver faster performance and improved efficiency compared to PIWIS 3. This speed enhancement allows technicians to diagnose and service vehicles more quickly, ultimately leading to increased productivity in the workshop. User Interface Upgrades The user interface of PIWIS 3 is designed to be user-friendly, facilitating easy navigation and access to diagnostic functions. However, PIWIS 4 may offer significant improvements in this area, providing a more intuitive and can significantly reduce the learning curve for new users and enhance overall operational efficiency. New Features and Functionality While both systems primarily serve the purpose of vehicle diagnostics, PIWIS 4 may come equipped with additional features, updated interfaces, and enhanced functionalities compared to PIWIS 3. These improvements are designed to meet the evolving needs of technicians in the field, providing them with the tools necessary to service the latest Porsche models effectively. In summary, both PIWIS 3 and PIWIS 4 are crucial for diagnosing and servicing Porsche vehicles, but PIWIS 4 stands out with its advancements in performance, compatibility, and features. The choice between the two systems ultimately depends on factors such as budget, specific diagnostic requirements, and the types of vehicles being serviced. As the automotive industry continues to evolve, having access to the latest diagnostic tools like PIWIS 4 will be essential for technicians aiming to provide the best service possible.
  5. using the PIWIS 3 diagnostic tool is a systematic way to troubleshoot and diagnose a non-running Porsche 996 and ensuring that the iconic 996 gets back on the road in no time. When it comes to diagnosing issues with a non-running Porsche 996, the PIWIS 3 diagnostic tool is an invaluable asset for technicians and enthusiasts alike. This advanced diagnostic system is specifically designed for Porsche vehicles, providing comprehensive access to the car's electronic systems. Good news! PIWIS 3 diagnostic tool Lastest Software Version V44.800.022 + V38.250.000 Free Update.
  6. PIWIS 4 supports the following features that PIWIS 3 cannot support: PIWIS 4 supports the latest car models from 2024 onwards. PIWIS I supports cars up to 2014 model year, PIWIS II supports cars up to 2017 model year, PIWIS III PIWIS IV supports vehicles up to 2020 model year, PIWIS IV supports all vehicles including new cars from 2023 onwards, also supports new models of electric cars. PIWIS IV also provides technical support for SFD diagnostic protection which PIWIS I, PIWIS II and PIWIS III cannot provide. PIWIS IV support for new cars from 2024 is very important for the ever evolving automotive industry. Every year, new vehicle models are introduced to the market, equipped with advanced technology and unique configurations that can make it difficult for technicians to accurately diagnose and service these new vehicles without the latest diagnostic tools such as PIWIS IV. With support for 2024 vehicle models, PIWIS IV ensures it keeps up with the latest automotive developments, providing users with access to diagnostic and maintenance capabilities specifically tailored to the needs of newly released vehicles. PIWIS 4 supports SFD diagnostic protection technology: Furthermore, the integration of SFD (System Fault Diagnosis) technology support enhances the diagnostic capabilities of PIWIS 4. Vehicle system faults can be complex and difficult to identify without specialized tools and techniques. The inclusion of SFD diagnostic protection technology support provides users with advanced tools and methods to effectively identify and resolve system errors. This feature improves the reliability and effectiveness of PIWIS IV in diagnosing and troubleshooting vehicle problems, ultimately streamlining the repair process and minimizing vehicle downtime. PIWIS 4 adds support for electric vehicles (EV): The additional support for new electric vehicle (EV) models reflects the growing importance of electric vehicles in the automotive market. With more electric vehicles being introduced in 2024, it is important that diagnostic tools such as PIWIS IV also evolve accordingly. Electric vehicles are equipped with different components, systems and diagnostic protocols than cars with traditional internal combustion engines. By supporting new EV models, PIWIS IV enables technicians to perform diagnostic, maintenance and programming tasks specific to electric vehicles, effectively addressing the specific requirements and challenges of EV technology. Further differences between PIWIS 4 and PIWIS 3: General developments in PIWIS 4: PIWIS 4 has significantly evolved from its predecessor, offering improved functionality, compatibility and security features. The introduction of support for electric vehicles reflects Porsche's commitment to alternative drive technologies. In summary, PIWIS 3 serves as a reliable diagnostic tool for Porsche vehicles, while PIWIS 4 takes diagnostics to the next level with advanced features. These include support for electric vehicles and the integration of SFD diagnostic protection technology to ensure both efficiency and safety in vehicle maintenance and service.
  7. Coding a tire pressure monitoring system (TPMS) is an important task for any automotive technician. TPMS is a safety feature in modern vehicles that alerts the driver when tires are low in pressure, potentially preventing accidents and improving fuel economy. One tool commonly used for coding TPMS is the Porsche Integrated Workshop Information System III (PIWIS III). PIWIS III is an advanced diagnostic tool that allows technicians to communicate with the vehicle's on-board computer system and tune various components, including the TPMS. To encode TPMS with PIWIS III, the technician first connects the tool to the vehicle's OBD-II port. Once connected, technicians can access the PIWIS III TPMS menu and select the option to encode the TPMS sensors. The tool then prompts the technician to enter the required information, such as the vehicle's tire pressure specifications. Once the required information is entered, PIWIS III communicates with the vehicle's on-board computer system and updates the TPMS sensors with the new coding. This process ensures that the TPMS is precisely calibrated to the vehicle specifications and provides accurate tire pressure readings to the driver. In addition to coding TPMS sensors, PIWIS III also allows technicians to run diagnostic tests on the TPMS system to identify issues or malfunctions. This helps prevent potential security risks and ensures that the TPMS is working properly. In summary, for automotive technicians, coding TPMS with PIWIS III is a critical task to ensure the safety and efficiency of modern vehicles. With this advanced diagnostic tool, technicians can accurately calibrate TPMS sensors and perform diagnostic tests to maintain the health of the entire TPMS system.
  8. Porsche PIWIS II diagnostic tool is designed to work with newer Porsche models and may not be compatible with older models such as the 996 and 986. It is recommended to use a different diagnostic tool specifically designed for these older models to diagnose any issues.
  9. Connect the PIWIS 3 to the OBD-II port of the 996 using the appropriate cable. Turn on the PIWIS 3 and select the 996 model from the menu. Go to the diagnostics section and perform a full system scan to check for any error codes. Check the fuel system by monitoring the fuel pressure and injector operation. Check the ignition system by monitoring the spark plugs and ignition coils. Check the engine sensors for proper operation, including the crankshaft position sensor, camshaft position sensor, and oxygen sensors. Check the battery voltage and charging system to ensure they are operating correctly. Check the engine compression to make sure all cylinders are within spec. Check the immobilizer system to ensure it is not preventing the engine from starting. Review the diagnostic results and address any issues found to get the 996 running again.
