911times2
Everything posted by 911times2
  1. I found a thread on another forum that indicated the Signal Seek button (#7) is used to save the code but it did work for me.
  2. With the help of CDR 210 manual download and reading several threads and forums, I was able to following the instructions and read the following codes: R2896 V5010579 The last message returned was END which has not been documented that I have found. I tried entering the above codes per instructions: 2896 - display goes to blinking 2 5010 - display goes to blinking 5 0579 - display goes to blinking 0 After several tries the display goes to WAIT and eventually it will let me try again. I found another thread that appeared like one of the above codes has to used against a master code list. Any ideas on why the above codes did not work? I found a place to order the removal tool to pull the radio and look for more info if that is next steps.
  3. Please ignore prior questions about CDR 210 button definitions. I was able to finally locate a download PDF (attached). Hope this helps someone in the future. I haven't tried the code reset procedure yet - pages 9 thru 11.
  4. Old Porsche guy - new member. Just got a new to me 1998 993 Cab and the radio is showing CODE due to a battery replacement by the prior owner. I have read this entire thread (and a few on other Forums) and found some instructions on retrieving the radio code for the CDR 210 radio but no videos or pictures or button location and definitions such as TONE and TP. Do I need a magnifying glass for these old eyes? Are special tools required to slip the radio out of the dash and look for the number? Anyone got a PDF file for this radio or a drivers manual ? Doesn't seem to be much posted on uTube. thanks in advance..
