Akbar
Everything posted by Akbar
  1. Just now figured it out on my ‘09 C2S Step 1. Press Info button Step 2. Press Option button Step3. Click the on screen option ‘Set PCCM System’ Step 4. Click the on screen option ‘Reset’ Step 5. Click the on screen option ‘Vehicle hand over’ (did not choose factory settings as did not want to rick loosing any version updates ir messing something else) Step 6 and 7: select Yes for confirmations to proceed. All devices should be gone now plus any other data like phonebook and navigation addresses. you may also notice that in the Source menu, some options like AUX/iPOD etc have also disappeared. Go to Source: Select ‘Disc’ (have to have a disc inserted and car engine running), then click Options and it takes you to a menu to select various sources to select and display in the Source menu Hope this helps. Good Luck
  2. Having same issue with my ‘09 C2S. Did you figure out a solution?
