cayvman
About cayvman
  • Birthday January 1
  • Interests
    Woodworking.
    culver city
    2004 Boxster S
    2002 Boxster S
cayvman's Achievements
  1. Have ruined the seats in a 2004 Boxster S (top down, rain and sprinklers). Shopping for used and LAdismantlers has a set of 8 way seats out of a 911 (don't know the year). Would like to know if anybody out there has made this switch or knows of anyone that has or knows if they would fit without having to make major modifications. The seats I have in the car are heated and 2 way (I guess). Thanks
  2. Thanks,all. will try either the fuse or relay option.
  3. Have upgraded a 2004 Boxster sound system (jl amps, pioneer avic130bt,focal speakers) using several of the diys posted here as guidance. my question is, has anyone figured out how to wire the switched power so that the stereo stays powered until you remove the key from the ignition switch? Thanks.
  4. Thanks for the diy. Question about glare. How is the on screen visibility with the top down and on a sunny day?
  5. Dharn55-can you tell me more about your speaker upgrade to Focals. Size,model. Did you have the Bose sound system?
  6. Picking up replacement ('04 Boxster S) for my totalled '02 Boxster S
  7. Did you replace the crankshaft position sensor with the engine in the car? If so, can you tell me how you managed to do it. If you have any pictures would be greatly appreciated. The location and access points are, from what I found this weekend, impossible. Joe
  8. Have p codes p1397 and p0336, and for the life of me, I cannot locate the cam sensor on the engine. I've seen diagrams so I know in the general area where the sensor is supposed to be located but haven't had any luck finding it. Has anyone replaced one, and if so, do you have any guidance or pictures you might want to share? Code says it's on bank 2. Also, any info on replacing the speed sensor would also be greatly appreciated. Joe 2002 boxster s
  9. Would not buy from Wheel Dynamics. Their service is questionable at best. Purchased wheels for my Boxster and they put the wrong size lug nuts on one of my wheels. It's been rubbing up against the parking brake and am waiting for them to send replacements. Their response has been, how can I be p.c., laxidasical. The owner didn't have the courtesy to return my phone calls and didn't have the stones to come to the phone. DO NOT BUY FROM THESE GUYS. If I sound pissed off, I am.
  10. I've had the same problem for awhile, codes P1128 and P1130, and could never find what caused the codes to keep coming up. Then this weekend I changed the spark plug tubes, O rings and spark plugs. Around Tuesday or Wednesday of this week after about 100 miles of driving, the CEL went out. Any ideas what the repairs I did would have done to effect the problem causing the fault codes to go away?
  11. While changing my spark plugs this weekend noticed this elbow shaped connector without anything attached and was wondering if anybody can tell me what it's for. Thanks.
  12. I guess my initial counter clockwise turning of the tensioner was the culprit. It loosened the back nut of the tensioner enough so that when I was turning the outside bolt clockwise the nut was turning. Once the light went on in me noggin of what was goin on and I tightened the back nut, the tensioner work as designed. Hope my experience may help someone else.
  13. PK, It's not that the bolt was tight, I could get it to turn, it's that the tensioner didn't move. I did get it to finally move. Did it the caveman method, took a rubber mallet and got it to spring to the left and was able to remove the belt. Hope I'm able to get the tension back when I finish the job. Thanks for your pointers. Joe
