Red9
Everything posted by Red9
  1. Anyone got any ideas where to ask?
  2. What models share the same body shell in the 997's? EG the 996 GT3,GT2,TT,C4S, GT3 RS, the race cars GT3 Cups, R,RS,RSR --all shared the same basic body shell that was different to others in the range. So --how do the 997's go?
  3. What are the issues with 997 series engines( 3.6,3.8) being fitted to 996? Would trans bolt straight on ( Tip in particular but are also interested in manual fit) . What would need to be with engine that is not interchangeable? Thx in advance.
  4. Where is the bosch unit available from/ /? What price is it/? Do you know of anyone that has used it? What problems are there likely to be in getting it to work? thx
  5. What if I simply put metric background to speedo? Does any mechanical part change or is it just the background?
  6. Like everything -- not a simple answer. It is an English loom and intruments--from the same car.I am in Australia-- metric etc. originals were water damaged--so rather than risk all the complications have opted to replace as much as possible.Cheaper than chasing individual problems!
  7. Can an imperial MPH speedo be converted to KMH metric? If so how?
  8. 3rd party. The same problem existed prior to flash. Sort of hoped flash might solve the problem!
  9. Car completely stock. Recent flash upgrade - problem was present before flash.
  10. 03 TT tip -- systems 2 says Air Mass Meter Fault. Car is OK on start up and warming up. Leave for 20 minutes and come back, ABS ABD does not work. It then hunts at idle and run rough. The Air Mass Metre has been replaced 3 times. Any help much appreciated
  11. Thankyou Loren-- much appreciated.
  12. Loren-- what does that mean to you-they are the same?
  13. Anybody? Any ideas ?
  14. In the 996 series body shells-- are the TT, GT 2 , GT 3 and C4 -- all the same essential shell( some external panels are obviously different ) ? Are all years 996 C 4 shell the same ? Thanks in advance
