C2SNerves
  • Future cars
    997 C2S
    911T
405 profile views
C2SNerves's Achievements
  1. Did you find a solution to your problem? i have the same problem and i am interested to know how you sorted it out??? thanks
  2. Has anyone experience whining sounds from the rear on a 997.2+pdk+LSD???? I have been going back and forth to my dealer with this problem. FInally they decided that this is standard with the LSD option with PDK, that there is a slight whine in the rear differential between 10mph to 60mph. This is not the grind or crunch sounds that come with the LSD while turning. This is WHINING, and it is very faint. Thank God the technician heard it. Usually they dont admit. Has ANYONE heard any such sounds? whether with or without LSD option?
  3. has anyone experienced a chunking sound on high gears with the pdk? when you are on a high gear (higher than what you should be on, like on 3 to 4 going 40mph)and you release the pedal suddenly, there is a mild chunk in the gears. Then when you press the pedal suddenly again you get the same chunking. the dealer said it is normal to have such sounds on high gears just as a manual gearbox. comments pls.
