alex222
Everything posted by alex222
  1. Looking for something else I noticed these plastic slides on the parts diagram. Anybody knows of what these are for? Seems like 4 are intended for the 996.
  2. Your radio is made by Becker. This model requires the PIN code once unplugged. Look in your Owner's Manual pouch it should be a credit card-size Becker card with a 4-digit PIN or if a prev. owner has written it somewhere. If you got your pup from an individual and not a dealership/resellers you can call the person and ask if he remembers the PIN for the radio? Alternate option you can pull the ratio out and there is a sticker with a serial number. Check on eBay if there is a service to pull the Becker PIN by the S/N. It used to be a girl some time ago she was pulling it like in 5' for $30 or so. Once you entered an incorrect PIN, you need to WAIT for 10'. I think it's 10, not 30.
  3. Can anybody confirm - I've read elsewhere that chime sound for unfastened driver seat belt they implemented in MY04 996.2 going forward. On my MY03 there is no any chime sound when I don't plug or unplug the driver seat belt, it only lits up the red warning light on the dash. I have the chime going off for the speed limit set thus it is there and it is in the working order.
  4. ABS failure with following PSM failure usually happen during the winter on the lower temps. Stop the engine, start the engine and it should clear. I've read it happens on 987 Caymans and it happened on my 987 Boxster 2-3 times like once per winter.
  5. Not at all although to your consideration your actual speed will be tiny higher as your rears have a 1/2" bigger diameter as your rears are 35 sidewall ratio instead of 30 required and the speed is calculated from your rear ABS tires RPM. The factory rim sizes for you are: 8-18 and 11-18 so your BBS are a little off and the sidewall ratio for the rears is 30 not 35 so your rears are a bit thicker because of that making it a little butt-up. But for the PSM it is no matter at all. My 2003 C2 Cabrio arrived at a time 2 years ago with 295 35/ZR18 because the seller bastards put in ExtremeContact DWS which is not having the size for 295/18 of the 30 sidewall ratio. So at some point in 2023 I got a set of 17" factory rims as 17" is the default rim size for the 996.2 and 18" is optional which is for MY2003 the factory had put all 18" rims option (which is on your hood label) so with 17"-s with the proper sizes PS2-s (205 50/17 and 255 40/17) the ride is a bit nicer/softer and the pup is horizontal as the proper size tires makes the pup absolutely horizontal no but-up but for PSM doesn't matter at all as it takes the input from your gas pedal position, PRMs, acceleration sensor, which one is the gear-in, and the ABS.
  6. I don't have a pic with the top opened up handy and it's cold in my area to open it up the soft top having a handful of the rubber-ish strings that don't like moving them when it is cold. But you can google it See p.85 of the manual (section 61-40): http://p914-6info.net/996_Manuals/996 Group 6 Body Exterior.pdf. Hint: Adobe Reader and MS Edge are not opening up the links on the table of contents. The Google Chrome browser does open them up. I don't know of any good Porsche shops in the Orlando, FL area. Usually, a good shop is not a next to your door like in "North Orlando". Dealers are usually the worst. They usually don't know anything beyond a capability of changing the engine oil/brake pads/shocks/springs or so. Get yourself familiar with this. It's the best to go to: 996 Workshop Manuals P914-6INFO.NET
  7. Loren, thanks. As I see the part number for a replacement part at the present time is 996 343 041 36 but the nature of my q is if used shocks 996 343 041 20 can be used for my pup? WP0CA29933S653275
  8. The ambient light sensor adjusts the brightness for the 3 displays on the instrument cluster. It's not the feature of "automatic lights" that been developed to the later models. The sensor is not switching the instrument cluster illumination ON or OFF when you are passing a dark spot or when it is getting dark. Those are with the "A- [lights symbol] feature. The illumination for 996/986 is switched on/off only by light switch knob. With the parking lights and instrument cluster illumination on, the ambient sensor adjusts the 3 panels brighter or darker as the it is lighter/darker in the cabin to the setting set by the adjustment knob. It does not adjust the instrument cluster back-light illumination. You can point your flash light from the smartphone on and off the ambient sensor while not driving with the engine on with the parking lights on and off and you see how the brightness changes on the 3 displays.
  9. Are you sure your L or R hydraulic cylinder is not dead? Take off the central carpet cover panel in the rear where the soft top is stored folded down and check if there is no oil all over by either of the cylinders? Also see how much oil it is in the hydraulic pump tank - it's off the center toward the RR wheel.
  10. P1130 - mixture is too lean so the control is up to the enrichment limit. That's on your passenger side cylinders 4-6. Start with replacing one then the other oxygen sensor on the passenger side. If the error comes back it could be as a leak in the vacuum line but also it can be a leak in the exhaust on the flange where the 3 nuts are. I had on the Boxster the [st*pud] and LAZY mechanics put iron nuts on the exhaust flange after the cat resulting iron nuts corrosion and erosion resulted in sucking in some fresh air to the after the cat so as I noticed the past-cat sensor is super-sensitive sensing more oxygen in exhaust gases more than before the cat = saying 'dude something is wrong w/ your pup' in English. I spent a half-day crawling in the wheel housing removing the remains of the iron nuts from the flange studs on the exaust pipe put the factory nuts by the P/N and that was it and all good since that and that was about 5 years ago.
  11. A little oil like on the picture inside the intake and that much on the napkin is normal. It comes from the oil separator.
  12. Hmmm... it's hard to say what you trying to do. Can you post the corresponding pictures?
  13. Are the front shocks for 996.2 C2 MY02 can be used for MY03? I tried to do some homework with the following outcome: MY 02: 996 343 041 20 MY03-04: 996 343 041 23 Currently offered by the dealerships for all C2 MY02 and MY03-04: 996 343 041 36 with mentioning a prev. part offered also for all MY02-04: 996 343 041 27
  14. Thanks! Makes sense. Interesting some models do have those (996/997, 958 Cayenne both front and rear) while others don't - 993, 991, the Boxsters. Talking about the Boxsters - the 986 front ones having this little stick, while for 987 same pads and they took this little stick off. What is it for?
  15. Just curious of what these metal cylinders on the front 996/997 brake pads are for? Boxster pads are not having those. Never seen such on any other cars neither.
  16. It was a cross-bar under the transmission pan got loose because I had overfilled a bit so the oil got to the mounting bolts + vibration.
  17. I lifted up the pup in a body shop I had stopped by for something else and checked the final drives and CV joints both tight and the inner joints are tight to the gearbox flanges. Seems all good. Not seeing anything loose in rear suspension on neither side. I have a spare set of aftermarket rear brake rotors with the aftermarket set of the pads in my garage that I replaced with the factory ones a year ago after I got the pup. Will swap those one side at a time see if it anything w/ the stock brake disks/pads or also there is an aluminum screen on the inner side of the brake rotor if anything is with it?
  18. Will do on the upcoming weekend but to my knowledge as I had replaced both inner CV boots on a 355 last Summer which was involving disassembly the inner CV joints with the ball bearing completely with reassembling; if it will be a wear in the CV caves on either shaft or the star and the CV joint is loose, it will be a push because of so at the beginning of the car movement from standing still but when clunk(s) happen are when the pup is few seconds already moving and during the clunking sound there is no any pushes or any movement distortion. As I looked the 996.2 and 987.1 final drives and the CV boots look very similar to 355. Probably the same or similar all made by Bosch. It is just the clunking sound. Or two. And, when driving somewhere say for about an hr, the sound is not getting repeating more often, etc. And I was driving at some times up to 60mph. All perfect. Shifting and everything.
  19. Inner and outer CV boots look great on both sides. I jacked the RL wheel up and rotated it back and forth on Neutral. It has some gap when moving it back and forth but it's not making that clunking sound if rotated up in the air by hands. I jacked up and did same back and forth wheel rotation on 987 which is with ZF19 gearbox. It has similar but smaller and less noticeable gap when moving it back and forth. The weel hub bearing? The wheel hub bearing on 996 seems perfect. The wheel itself rotates with no any noise.
  20. I got a single (sometimes 2 in a row) clunking sound on a MB 996.2 automatic transmission when the car starts moving from a complete stop. The sound comes after the car moved 2-3 feet forward (or in Reverse too). I changed the ATF oil 6 months ago topping it off on a running engine then added more after switching in-gears for 10sec for each. I a little bit overflown it as now on a few days @75F a few drops came out from the breather cap in the front of the transmission a month ago and then stopped and there are a few oil drops came down in a rear on the top of the torque converter drain plug (the MB transmission is having so). The car shifts absolutely perfectly otherwise. The clunking sounds started coming a week ago when weather got some noticeably warmer and it comes not after every full stop but often. Sometimes one, sometimes two clunks. Is it because of a possible oil overfill? What this clunking sound could be after the car starts moving? With a radio on it's hardly noticeable. The clunking sound is appearing coming from the RL wheel housing. I checked it's not coming from the pads nor the RL brake rotor is turning freely with a transmission in Neutral. No any scrubbing on the park brake pads which I adjusted exactly a year ago by the 996 workshop manual procedure.
  21. Turned out it is not. The clamp is 1" and the hose is 1/2" and the flat pin is twice thicker than the mounting hole on the clamp. That's all right. Maybe there is no clamp supposed to be in there?
  22. It supposed to clamp one or 2 an inch-thick water hoses. Those water hoses run one on top of another across the body, just above the rear edge of the under-carriage plastic shield. Not sure if it goes to hose #8 but seems it's the only clamp with a flat hole to go over that flat pin on the picture I had taken.
  23. What kind of a clamp is for the water hose by the front end of the MB automatic gearbox on 996.2? Is it 996-106-419-52?
  24. According to your statement I called a local dealer yesterday and asked to pull the options for my 987.1 which I also having and it aslo is having Tiptronic. Turned out, it has an option 195 70Ah battery and the guy said the factory ships Boxsters over with 70Ah batteries to only get overseas which they change to 80Ah. But, sometime ago I had put the factory 70Ah battery which lasted only for 2 years and I switched back to 80Ah battery. I said back to the dealer if according to them the factory puts 70Ah Boxsters to only to get a new car shipped overseas, why my 996.2 is having the option 197 88Ah stronger battery for the first place? - He didn't respond with anything.
