Jim Long
Everything posted by Jim Long
  1. First, grab a vacuum and start sucking out the loose foam from the vents. This debris is coming from foam that is failing on the HVAC blend doors. Prepare to be hit in the face with small debris for a loooong time if you don't take action to remedy these foam-covered blend doors in the HVAC system. There are a few approaches to help remedy this outside of removing the entire dashboard. Check YouTube / Google search this topic. It is very common. Second, the vents can be removed by inserting two, long sharp prongs into the lower portion of the vent to raise two tabs that contain the retention tabs. It will take two hands and a pulling action to remove but once you have done it once, you will be able to more easily do it to the others. The little slats can be fixed in place if the retention hooks behind it have not been damaged. I have found many doors in your condition because people were "fishing" out the foam pieces and dislodged the slat(s). You can use a hook tool to pull the retention piece back towards the slat to re-engage it so that it moves with the rest of the slats. Grab a flashlight and see if you can understand what I am talking about.
  2. Thank you vza! I would also like to see the vids when available.
  3. Would you mind posting anything that you learned in the process? I would also like to do the same job but as you said, the info is scarce.
  4. You may want to watch this video. It is not exactly what you are looking for but it will give you some ideas.
  5. I understand the windshield washer tank capacity to be about 6 liters. Ref: 2006-2013 Porsche Boxter, Cayman Specifications WWW.YOUCANIC.COM Look up Porsche Boxster Cayman specifications, engine oil capacity, spark plug gap, safety rating, fuel consumption, transmission, and light bulb sizes.
  6. Ok! Great news so far! I like the siphon idea too...
  7. Did you re-check your washer level? Did you find that it was indeed leaking? How did the top cleaning go?
  8. Great job Jim! And now you know how to remove the headlights in case they need polishing in the future.
  9. How did it go Jim? Was it easier for you than expected?
  10. Are you trying to remove the entire tank or just replacing the pump?
  11. I agree here that the nature of the issue being reported over 5 cylinders is less likely to be a coil pack or spark plug issue. I concur with JFP, it could relate to the MAF (mass air flow) sensor not sending the correct airflow information to the ECU so that the fuel can be "matched" appropriately when injected into the cylinder thus causing a misfire due to the imbalance (or stated another way: the engine is "hunting" for the proper balance of air/fuel mixture).
  12. I cut open the old charcoal canister after replacing it and found that the flow of vapor was being restricted by the moldy, hard charcoal of the outflow section of the canister. The inflow section charcoal was clean and perfect hinting that the moisture entry was from the other side. If you have difficulty filling your 987 or 997 with fuel (pump shutting off quickly or fuel spitting back at you) without any recorded DTCs, consider the charcoal canister at fault. This system is identical on 2005-2012 Boxster/Cayman/911. How moisture entered into this section and turned it into a semi-solid block over time is unknown, but it clearly affected the fuel filling capability by restricting the outflow of fuel vapor. Measurable flow was present in the old canister but when the new part came, the difference in flow was obvious.
  13. Ok, I figured out the answer: During fueling the air escapes the top of the fuel tank into a hose connected to the bottom of the charcoal canister. There are two exits the air can take after entering the charcoal canister: 1. through a small diameter line to the back of the car which is normally closed at the purge valve (or regen valve if you prefer). --> this is only open (vented) during normal engine operation per ECU instructions, not at all related to fuel filling at the pump. 2. through the leak detection pump (LDP) system port attached to the canister. --> this was the confusing part because I thought the LDP was only a one-way system, allowing flow into the canister for pressurizing the system to check for pressure drop (i.e. leaks) --> turns out, when not pushing air into the canister per ECU request (for example, during engine off refueling at the pump) it allows air to flow back through the LDP and out the air filter attached to the LDP. THIS is the primary way the 987/997 vehicles vent fuel vapors to the atmosphere during refueling. So, after further tests, the flow rate through the charcoal canister has to meet a minimum flow rate to allow for continued fuel filling operation. For reasons yet TBD*, the flow rate of vapors through my charcoal canister were insufficient to keep up with the needs of the escaping vapors from the fuel tank. *I plan to cut open the canister to see how it has become restrictive to flow. Solution: replaced charcoal canister (currently NLA Porsche) with a used one found on eBay. Fueling function fully restored.
  14. 2005 Boxster 2.7L Manual transmission I am trying to diagnose the problem of not being able to fill more than 2 gallons of fuel without it spitting back at me. Just to start, I've tried: 1. the "turn the filler nozzle sideways / upside down" trick ---> does not work 2. multiple gas stations with different types of vapor recovery nozzles ---> does not work Background: I've owned the car for approximately 10 months. It has always been difficult to fill. Lots of stopping / restarting of the fill process but recently gotten worse whereby fuel is making its way back up the fill tube and spraying out of the neck filler. Not cool. High level diagnosis: air is not being evacuated from the tank during fueling. I have no DTC's and no issue in starting, drivability, etc. I have read the previous discussion on this subject here: I have also read similar issues on other sites including two official tech training videos on the EVAP system including the subject of ORVR (Onboard Refueling Vapor Recovery). Most issues discussed on other sites relate to trouble code concerns usually landing on the common purge valve issue where it fails in the open position (relating to too rich, too lean, fuel trim issues, etc.). None of the training was 987 specific as each manufacturer has to package their own systems of parts to meet the emission requirements but the basic concepts remain the same. Here's where I have examined / tested my system. 1. Removed the tube from the tank vent to the charcoal canister and blew air through it - clear, no issue 1. Blew low pressure air down through the filler neck and witnessed air coming out of the top of the fuel tank vent - clear, no issue 2. Removed the charcoal canister and blew air into the inlet - clear, no issue, no charcoal bits or pieces found anywhere, smell of canister was very faint of gasoline (so I assume it is not saturated) 3. Examined the LDP (leak detection pump) and wiring, appears clean with no issues, air filter is like new clean. 4. Separated the purge valve from the forward cabin (connects at rear of cabin low, driver's side USA) and blew air from the carbon canister outlet connection to this rear port - clear, no issue. 5. Removed the purge valve and its related tubing from the air intake down to the rear port 5a. Tested the purge valve actuation via Durametric before disassembly (clicked open, no issues) and on the bench under vacuum (same, no issue), electrical resistance measured 24.4ohms 5b. Ordered new purge valve for replacement anyways (due to pain of removal, not risking a future failure of a 17 year old component and having to go back in there) 5c. Completely disassembled the purge valve and noted no trouble found in any physical internal components, retested electrically and watched the unit operate correctly sans plastic housing. 5d. Blew air into the remaining tubing leading from the rear port to the air intake - clear, no issues. 6. Replaced charcoal canister connecting it only to the fuel tank and went to the gas station - filled fine up to 2 gal and then continued to fill "full blast" until a total of 6 gal was added to the tank - no issues. Since this last step worked with an open atmosphere vent in an otherwise closed system I now suspect that I have not identified all of the venting that occurs during the ORVR process. I believe this vent, generically called the vent solenoid, is a part of this part on the top of the fuel tank: Does anyone have any more info on this component or how the ignition off, power off refueling sequence works to move tank pressure and allow fill-up on the 987 platform? Thanks to all who have gotten this far! Jim
  15. Have you checked the transmission and or engine mounts? Are you sure the noise is transmission related (i.e. coming from inside the transmission) because this would not be common with an otherwise normal driving car.
  16. It was assembled so it can be separated. It may require grinding down or cutting if it was assembled with heat staking for example. Have you made any progress yet? Reassembly may not allow you to use the same technique to attach (i.e. if it was previously heat staked), so make sure you think that through before making any non-reversible actions. Why are you trying to separate it?
  17. There is a lot of things here to consider. Have you got it started yet? Did you reinstall the crank position sensor? Make sure all of the things you removed are back on / plugged in.
  18. Misfires can occur due to faulty / old coil packs or plugs. Take a look at the coil packs, especially cylinder #4, and make sure none are cracked or showing any sign of exterior damage that may indicate internal issues. Even if you don't see anything, make sure they are the latest design and if they haven't been replaced recently, consider replacing all 6 along with the plugs. Many vendors sell a full kit for around $300 (as of Dec 2022).
  19. I lean on the official parts catalog available directly from Porsche. It is a searchable pdf and can be used to find ANY part on the car. I then use the part number and search for places to buy the parts. In many cases there are Porsche dealers offering online discounts that exceed many of the non-Porsche on-line vendors. Porsche Classic Genuine Parts Catalogue WWW.PORSCHE.COM The fascination of Porsche is timeless. How can you tell? Because more than two thirds of all the Porsche vehicles ever built are still on the road...
  20. You should post this in the 986 forum, it may get more attention there. High pitch noises are sometimes too general to offer a diagnosis without more detail but on a Boxster they usually originate from the pulleys on the front of the engine which rests just behind the seats. This noise can also be an indicator that the water pump is failing. It's a good time to get this diagnosed as to not leave you stranded if the water pump does fail. When was the water pump last changed? You posted this in Jun, so have you sorted this problem out yet? Could you offer more details?
  21. Actually, Porsche does sell the circuit board part of the rear tail lights separately from the tail light housing. For 987 vehicles, including your 2005, the part numbers are: 987 631 453 02 Bulb carrier left 987 631 454 02 Bulb carrier right If you search the web using these part numbers you will find a number of vendors, even Porsche dealers, happy to sell with varying discounts from dealer list prices (i.e. cheaper than walk-in prices). Ebay can also lead you to many choices for this part with a varying range of buy it now prices.
  22. A Durametric can scan and provide you with the fault codes needed to help you solve your problem. The fact that the car cannot sense tire pressures in one, two or even all 4 tires would not affect the PSM (Porsche Stability Management) system. A quick trip to a local tire place, even Walmart's auto/tire, can help you diagnose the 2 tire pressure sensors as these sensors can be scanned separately from the car's ECU. Once these are confidently working you can attack the other issue more directly without concern for the TPMS (tire pressure monitoring system) having caused the issue. Regarding the PSM, let's make sure that you haven't turned it off manually? (Of course you haven't). Also, turning the car off/on would recycle the system back to "on". But, do you know if the manually actuated PSM button works or not? I think that there is a chance, albeit a very low probability, that the switch has gone bad and is providing an "off" signal to the car continuously. A Durametric can be helpful here to. It can allow you to test buttons.
  23. I am surprised to hear that you changed the plugs but not the ignition coils. Is that true? Most ignition misfires/stutters come from faulty ignition coils as they are prone to go bad over time. Plugs are almost never the culprit.
  24. The high probability fix of the P0491 & P0492 error is to replace the secondary air valve. The valve is prone to fail over time (seize) and not allow the pump to flow air into the exhaust thus causing the P0491 and/or P0492. Use a Durametric or similar on your non-running car, actuate the air pump and check for flow out of the tail pipe. No flow? Blocked secondary air valve. 948 113 203 51 Secondary Air Valve You must remove the right (pass) side intake and injectors to complete the job so also buy yourself new gaskets for the intake and the injectors for good measure.
  25. And where exactly are the locations of relay support 1 and relay support 2 within the 987.1? Are these the correct locations?: "Found one panel up under the dash (drivers side) which looks like it will be the most difficult to get at (maybe need to remove the lower dash panel to access that one). The other appears to be in the rear, behind the carpet on right side of trunk."
