PAULSPEED
Everything posted by PAULSPEED
  1. Hold on to it until the market improves. Sell your car to a consignment dealer. Paul
  2. I do not think so. You test the voltage with the car off. The only light running is the trunk light and that does not take much. Paul
  3. You first measure the voltage across the battery terminals. Then you push a pin (like the one you get when you buy a new shirt) in the cable at the alternator. The alternator is on the driver's side on top of the motor. Then you measure the voltage from the pin to ground. You will know if you need a bigger (like the 997-2) alternator cable if the voltage is less. The voltages should be close to the same give or take 1/4 of a volt. Paul
  4. It is my screensaver at home and at work. I like it too. Paul
  5. There is more to the Cup car race car. Motor rebuilds after 50 to 75 hours. Transmission rebuilds from 75 to 100 hours. The suspension alone is worth a lot. I think the bottom a-arm is $750 and the Flying Lizard team replaces them after every race. They are extremely light and use a special high strength metal. Just slide your car sideways into a curb and open the wallet. I would recommend a tube frame 997 car with a race spec motor. You will have more fun and do more racing then watching. Paul
  6. Here is another Lizard picture. Paul
  7. There are small drains near the battery. They go to the underside of the car. A small wire is all you need to make sure they are open. Clean the leaves out around them. Paul
  8. I use two 2 by 6 by 6-0 long boards to get my car into the garage. Yes they have cracked some what. Good luck. Paul
  9. Looking to replace the wing motor. It makes alot of noise going up and down and just got stuck the other day. I cleaned the runners which seemed to help. Is this one of those all day projects or is it some what easy fix? Thanks for any feed back. It is part 13 in the picture below. Paul
  10. Sorry I do not own a Panamerica. I was looking at a friend's car when I noticed the spot. Maybe I can get one at Rennsport in October. Paul
  11. I am thinking that the tabs are used for holding some part for the steerable headlights. Here is a picture of the compartment area. Paul
  12. I have another picture but it only shows the 3amp light bulb. I would phone Sunset Imports and ask them if they know anything about parts for the interior lights. Maybe there is a part for a fuse on a wire leading to the glove box. There in Oregon so you will need to call them in the evening. Here is their 800 number. 1-800-346-0182 Again, good luck. Paul
  13. I just was looking at the motor in a V6 car. On the passenger side looking at the motor there is a small compartment near the left hood line. There are two factory painted tabs with no weld nuts behind but it looks like a space for installing a cover plate. I called it a future stash box for hiding money, keys, etc. The only thing I could guess was that it was a space for the ABS valves when a V8 is installed. Anyone else wonder why they built this compartment? Paul
  14. The 80 amp fuse is near the battery. Looks like part 11 in the picture. The glove box is a 3 amp light. I would look for a small fuse on the wire to the light. Good luck with your search. Paul
  15. Save your money and get Radiators and hoses for a southern California car. Paul
  16. You might have cooked the control unit with voltage. The tool can tell if it is bad real quick. Paul
  17. The part 7 and 8 are the adjusters for the cables. Maybe you need a little adjustment. I would drive another car to compare. I drove a car with a short shifter and it shifted just fine. I would pull the shift boot and go thru the gears. I would then add Vaseline to any surface that seemed a little tight. Vaseline is a petrolume by product. Paul
  18. It is the transmission cooler on top of the transmission that is in the way. Paul
  19. I would change the pollen filter. It is next to the battery. Paul
  20. There also is a larger(Fatter) cable for the 997-2. The 997-2 cable works great on a 2006 car. The bad news is the motor needs to be removed for a tip car. Rumor is that it can be done with a manual. A dealer near me replaced one with a tip, but it was extremely hard work to do. Paul
  21. One of your window slide rails might have a loose nut. There is a DIY for removing door trim by me. Here is a link. http://www.renntech.org/forums/tutorials/article/7-door-micro-switch/ Paul
  22. I have over 103,000 miles. I ran it hard at about 15 to 20 days of track use and blew the motor at 67,000. I replaced the motor on a hard ship issue and only had to pay labor for the motor. The car does run hotter even after I cleaned out the raditors. Besides that, the car works great every day. 2006 997S Paul
  23. The voltage should not change. It's the amount of amps and you need to cut the wire to read amps. Paul
  24. I found the cam chain tensioner. http://www.flat6innovations.com/shop/home.php?cat=316 Paul
  25. Can be impossible depending on what wiring harness is installed. You then would need to go to non-factory. Buying the leather is OK but expensive. Paul
