ptam28
Everything posted by ptam28
  1. That worked, thanks.
  2. Hi Guys, Any suggestions on this? Seems that the release doesn't work from inside the car. I have tried the emergency release cable tucked next to the passenger side lamp. Thanks in advance. Patrick
  3. There are usually folks who are selling their amber turn signals since they bought the clear ones as well.
  4. That was exactly my thoughts too, so I went with the real litronics kit. When all is said and done, the cost of these aftermarket kits vs. the real litronics kits with the proper optics, etc. isn't that much more considering how much better you can see at night with it.
  5. I had a problem with my secondary injection and it turned out to be the change over valve was not working.
  6. There are some kits out there that have the bulb adjusted so that the focal length is the same as the stock halogen bulb. You don't get nearly as much stray light. The distance was about the same as the stock halogen, but it was much brighter though. I had used one of those kits when I had a Toyota Supra and it worked out pretty good.
  7. I think the lens melting comes from the folks who use those higher wattage white bulbs (80w+). The aftermarket HID ballast and bulb kits are actually lower wattage (35w vs 55w) than halogen bulbs. That being said, the stock halogen lenses are not designed for the HID light, as stated earlier, the light dispersion and cutoff aren't going to be ideal. You'll have a lot of stray light, there are some kits that have the bulbs focal length adjusted, so that will help minimize it. So although you will increase the quantity of the light, the quality of the light you'll get won't be significally better.
  8. My relative was able to purchased just the shift boot portion as a porsche oem part. Let me see if I can get the part number from him and get back to you on it.
  9. When I put my GPS sensor in, I was able to loosen the bracket that the IR sensor in place and drop the wire in that way instead of going through the defroster vents. This drops the wire directly behind the radio.
  10. No, there isn't anything special you need to do for the TrafficPro to recognize the cd-changer. When we plugged mine in and it saw it right away. I added the changer in after the TP.
  11. We've got Fastrak here in California (similar to the EZPass) and I haven't had any issues using it. I place mine in lower corner of the windshield on the driver's side.
  12. This plugs into your factory harness w/o having to cut anything. Just connect the wires to the alpine supplied harness and you should be set. http://www.installer-data.com/item/display....php?it=70-1784 It is Metra 70-1784. Maybe your local circuit city/best buy/good guys may have it in stock too.
  13. 3. I've got a good working CDR220 that I have out of my car that I can bring to the next work on cars day to isolate if it is the head unit itself. 4. I'd check the center console between the seats. Frequently I open it to get something out but don't close it all the way to where it clicks and get that. 6. When you take apart the mirror, you will find that the small metal "U" shaped clips popped out. I epoxed them back into place and it has been fine for a while now. I went ahead on the other mirror and did the same thing.
  14. I believe that Pentosin CH11S is the same as VW/Audi's G002000. It is more expensive to buy the VW stuff than to buy Pentosin. I think I bought mine locally at Griffin Motorwerke in Berkeley for about $14 for my VW when I had a slight power steering leak. But that was about 4 years ago. I'll swing by and see if they still carry it and how much it is.
  15. Make sure that the cables are all the way inside the guides so that when you release the spring, it should go over the cable completely. I found that I had to push the cable down to where it "clicks" into the guide.
  16. I ran into a similar situation where I didn't have the radio code card either. However, right before I took it to the dealer to get the code, I found it on one of my service orders. However, I found out that You can use the TP method to get the unit's serial number from the unit and contact Becker North America parts department. They can be reached at (888) 423-3537x1209.
  17. I think I bought Pentosin at http://www.germanautoparts.com/ when I had my Corrado. Still have a bottle...
  18. I haven't gone to one of his clinics, but he did lead a drive for the Club Lexus meet which was the same as his drive route he takes. It is lots of fun and pretty much an all day affair. Patrick
  19. I've got the amp in the trunk, so for my install, I need to splice connector A Pin 5 to connector C Pin 6. On the CDR-220 and the Porsche Traffic Pro, Connector C Pin 6 is the Amp power on signal, on the HK, that connector is subwoofer out. As Henry says, probably the hardest part is connecting the reverse wire. It will work fine without it as long as you don't ground it. My understanding is where it will make a difference is if you are in an area that there isn't any GPS coverage and you drive in reverse, the system will not know you are going reverse and think you are going forward. However, once you receive the GPS signal, it should correct for it. Henry: You gave in and got it, huh? Patrick
