GrantatRenu
About GrantatRenu
GrantatRenu's Achievements
  1. We put a PCM delete and a set of Recaro racing seats in this 997.1, still have factory seat belts, and were able to code out all the air bag modules (Thorax, Pretensioner for seat belt, AWS and Buckle) and for some reason we can't get the light to go off and following two codes to clear: 8045 Driver's Belt Tensioner, incorrect Coding 8046 Passenger's Belt Tensioner, incorrect Coding I've played with PIWIS endlessly trying to recode the gateway module, everything I can think of to no avail. Does anyone have any suggestions?
  2. 2008 Cayman, all original, no ecu flash or any mods. No issues, runs great. Wanted to run an over-rev report and can't get my scan tool to connect to the DME. I've tried PIWIS as well as AutoLogic (report attached). AutoLogic says "ECU not responding". Coincidentally I have a cheap little "Zurich" OBDII reader that connects, shows that all my readiness monitors are green lit and reads live data like the engine RPM's, so I'm not sure why the other scan tools can't connect to the DME. All the DME/OBD fuses in the driver footwell are all good. Any ideas of what I should try? VehicleReport (1).html
  3. Trying to help out a customer on their car: Becker CR-220 Becker 1 Serial: Y5040634 24/99 EDIT: Dealer contact reached out to us with it. Thank you though Loren for this help that you provide the Porsche community. You're a hero in my book.
  4. I have a TPMS error on the instrument cluster, and after putting a new sensor in that corner my tire shop told me that there is no coding for the driver front tire in the TPMS module. They said it was something they'd never seen before. They mentioned if there was a code there (pictured), they could use it to get everything working. I have a PIWIS III, but am brand new to it and don't know anything about how it works. Is there a way to "program" a code into that TPMS module?
