Chih W
Everything posted by Chih W
  1. Is it safe to use this on Porsche macan?
  2. No. But I think it is air suspension compressor air filter. And it seems like for this car their purge valve is the crankcase check valve. Or am I looking for the wrong part? When I tried looking for purge valve for my car the 2 breather valve would show up
  3. Is it suppose to be disconnected like that? Do you know the part number by any chance
  4. It is on top of tire behind headlight. Took off the covering. Not sure if that hose goes with that and if it does then should there be a adapter to go into that valve or canister thing?
  5. And for the battery issue does it mean that the dealer will solve the issue when I bring it in
  6. P0441. I need to just know why is the solenoid stuck open.
  7. And radiator louver only closes but don't open and cause the car to over heat. It told me that the shutter was in a implausible state and need to re learn. Doesn't that mean the motor is broken so I need to replace it snd relearn it.
  8. I used launch x431 mini pro and code came up with like and same Car Scanner ELM OBD2 DTC report Selected brand: Porsche VIN: WP1AG2A52HLB52876 ============1============== 1441 Raw code: 0005A1 ECU: Engine control unit Status: Pending, Confirmed, Test failed since last DTC clear ============2============== 1443 Raw code: 0005A3 ECU: Engine control unit Status: Test failed, Pending, Confirmed, Test failed since last DTC clear ============3============== 1441 Raw code: 0005A1 ECU: 01. Engine control unit Status: Test failed, Pending, Confirmed, Test failed since last DTC clear Status bits: 1 Priority: 1 Frequency: 10 Unlearning index: 255 Odometer: 181036 km Date, time: 2022.03.27 16:58:57 ============4============== 1443 Raw code: 0005A3 ECU: 01. Engine control unit Status: Test failed, Pending, Confirmed, Test failed since last DTC clear Status bits: 1 Priority: 1 Frequency: 7 Unlearning index: 255 Odometer: 181037 km Date, time: 2022.03.27 17:37:01 ============5============== 40960 Raw code: 00A000 ECU: 17. Dashboard Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============6============== 0289 Raw code: 000121 ECU: 22. Four-wheel drive Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============7============== 0020 Raw code: 000014 ECU: 5F. Electronic Information System 1 Status: Test failed, Confirmed Status bits: 1 Priority: 4 Frequency: 1 Unlearning index: 240 Odometer: 181036 km Date, time: 2022.03.27 17:23:55 ============8============== 0007 Raw code: 000007 ECU: 5F. Electronic Information System 1 Status: Test failed, Confirmed Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 240 Odometer: 181036 km Date, time: 2022.03.27 16:58:26 ============9============== 0008 Raw code: 000008 ECU: 5F. Electronic Information System 1 Status: Test failed, Confirmed Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 240 Odometer: 181036 km Date, time: 2022.03.27 16:58:26 ============10============== 7178 Raw code: 001C0A ECU: 5F. Electronic Information System 1 Status: Test failed, Confirmed Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 240 Odometer: 181036 km Date, time: 2022.03.27 16:58:29 ============11============== 13705508 Raw code: D12124 ECU: 6C. Rear view camera system var.1 Status: Test failed, Confirmed Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 240 Odometer: 181036 km Date, time: 2022.03.27 16:58:32
  9. Edu code 1441 for sure. Along with 1443
  10. 1441 would be on and Is stuck open. Gas mileage is horrible. Like crazy horrible. Do I replace the solenoid or the valve? And also there is a code for open circuit between radio and antenna 2? . And my key fob signal only works when it's right at the key hole? Before it starts when the fake key in the key hole but now I have to insert the key to start. And reverse camera and sensor don't come on but when I check with obd tool it says no problem with the sensors but communication is not made to the reverse camera. 2017 macan gts
