Mafo
Everything posted by Mafo
  1. the vehicle has 47,000.00 original miles
  2. i have c2 carrera 2006 ,i have a problem when warming up ,the vehicle start perfect and work perfect in cold start for one minute ,after a minute if i push the gas,the vehicle idle is rouhg missfire, hesitate ,but when the vehicle gets to full warm up and the oil gets 200 the engine work perfect ,i conect the Autelmaxys OBDII pro to Read live data when engine running ,as a result the crakshaft angle and deviation sensor is about the average of the range ,,catalystic sensors works fine , i already change the following parts : spark plugs,Aos oil separator,fuel inyectors,fuel pump,maff sensor, battery ,coils ,and also took off the valve timing selenoide ,tested with a battery and clean ,put back on ,there is no problem there ither ,before i clean de throrttle body, stalled a new air filter ,i have no engine warning light in the dasboard ,no DTC CODE ,i have no idea what else to do ,with this problem . any sugestions ?
