Halu17
1 Follower
    Madrid, Spain
    Porsche 996 Carrera 2 cabriolet 1999
    Porsche Cayenne S 955 2005
    Porsche Panamera s e-Hybrid 2014
    Audi A1 1.4TFSI 2011
    Audi A3 8L Swap ARL 2000
    Audi S3 8L AMK 2001
    Audi S6 4B C5 4.2 1999
    VW Passat 3BG 1.9TDI 2001
    Hyundai H1 2.5CRDI 2008
  • Future cars
    996 turbo
    Panamera diésel
    Cayenne diesel
    Seat Marbella
    Audi cabriolet 2.3E 1991
    Audi cabriolet 1.9TDI 1999
    Vw beetle electric swap
    996 carrera 4 electric swap 1MW (2 Tesla model s performance drive units) working on it
225 profile views
Halu17's Achievements
  1. Hello my solution for the issue was changing the electrical vacuum pump relay under the passenger seat on the Panamera. hope this helps.
  2. Have you test vacuum pump working good, vacuum Lines, vacuum presure sensor and check valves?? if there is a vacuum leak the fault code would be the same
  3. Also I have notice that since I have repair the relay, and hybrid mode is back to normal, when the car is Parked for a week even when charged is plugged , 12v battery gets full consumed even if the HV battery is at 100% I have also that problem before the P0556 fault code but since I have that error no more battery problems. before, when not plugged to charger and a week parked the HV battery also get to 0% and then the 12v. On the past the Dealer make test and try to reproduce the fault and they tell all is ok and there was no problem but that is not true as both battery’s keep discharging. Anyone with same problems? Any clue??
  4. I think on cayenne maybe could be different location. The relay I have changed is the atached one:
  5. Hello, just update that I have find the issue on my Panamera, after testing all posible components, it was the vacuum pump relay, that is located under the passenger seat. the relay itself sems to work fine but even when activating it’s solenoid, it was no connecting correctly the positive terminal for the vacuum pump. The contact was not good, so replaced the relay and all issues have gone. hope this could help you!
  6. Hello, it´s only a official Porsche PDF, please find attached the screen shot of that document, hope some one know what is happening. Any one have documentation about what the Guided Fault Finding and Diagnosis Information says about this vacuum System?
  7. Hello Same problem on 2014 Panamera S Hybrid Found this tech document on internet. Any one know what to check? I think is not a good solution to change the 3 complete vacuum lines. for only a leak o problem on one specific part. As the systems detects a vacuum problem it disable the electric mode and turn on the engine to ensure the mechanical vacuum pump to work and that way preserve vacuum for the brake booster.
