Mauro Chianese
Everything posted by Mauro Chianese
  1. Hi Joe. Sorry i prefere to continue the conversation on post behind becouse i think it's appropriate:
  2. Hello everybody, i'm a new user and this is my first message (I have a 99 C2 Cabriolet Automatic). I have the same problem and i have just replace the ignition switch but the problem remaining. I found this video that show what is the problem: https://www.youtube.com/watch?v=Db0sYars7f4&list=PLwL2oesXs5pFzOFsUqdINfA0vhUWub1m8&index=30&t=0s Someone have found a solution? Here the list of my test done: 1) Verify all fusible. Alls are ok. (no improvement) 2) Replace the ignition switch with new one. (no improvement) 3) Disconnect the ignition switch wire connector. Inside it there is a little button. This button is pressed when you put the key inside a hole and start to turning on. When you tourning off the Key, in the exact moment of unpressing inside button, the dash light came off for half a second and return on with blinking hour clock. (no improvement) 4) I try to chek all the relay behind rear seat but all are ok (because i hear a buzz simultaneously unpressing inside button of step 3). (no improvement) 5) Disconnect the B1 fusible for disable current on dashboard to avoid to disconnect battery every night. 6) Unmount Gauges and verify the correct function of button to set time. (no improvement) 7) I view this video and the guy resolve with a used gauges, but i read in other post on the web a guy has replaced the gauges but the problem persist. https://www.youtube.com/watch?v=3BiF2r4kkzc&list=PLwL2oesXs5pFzOFsUqdINfA0vhUWub1m8&index=27&t=35s 8 ) Unmount the Light switch and disconnect the wire plug. When the wires are disconnect, the problem persist. (no improvement) 9 ) Here another post (not resolved) with the same problem in a Boxter https://www.renntech.org/topic/38497-99-boxster-dash-lights-wont-turn-off Many thanks in advance. Mauro
  3. Hello everybody, i'm a new user and this is my first message. I have the same problem and i have just replace the ignition switch but the problem remaining. Someone have found a solution? Many thanks in advance. Mauro
