MissMy70911T
About MissMy70911T
    Iowa
    1970 911T
MissMy70911T's Achievements
  1. What is the torque spec for what the parts catalog calls the "transverse struts:" on the front of a 2001 996 Carrera 2? They live under the front plastic spray cover, it's two two braces that run diagonally toward the front end. One end bolts about where the firewall is and the other ends and bolt on just in front of the front sway bar. Thank you RS
  2. Thanks to all the great posts here I was able to replace the water pump on my 2001 996 C2 Tiptronic but now the high-speed fans won't come on. The low speed works fine when I turn on the air conditioner but there is no high regardless of the engine temp. What is my next step in diagnosis? Is it possible that I caused a problem during the fill up process which requires removing the B1 fuse? I've taken it out and replaced it a fe times during the filling process (I flushed the coolant twice, it was disgusting). What can I do to get the engine back on track?
  3. What's the technique for flushing the impeller chunks out of the cooling system on my 2001 996 C2? Do I put a hose into the filler tank and just let it run? Do I need to start from the front of the car and work back? What is the magic sequence? When I pulled the water pump on my 2001 996 C2 and noticed that a couple of the impeller vanes are chipped. I've filtered the drained coolant and haven't found the bits and pieces. I
  4. It worked! Thank you. 2001 996—Same sad story as everyone else. Model: CDR-220 Type: 4462 Serial No: 15075086 Thanks!
  5. 2001 996—Same sad story as everyone else. Model: CDR-220 Type: 4462 Serial No: 15075086 Thanks!
  6. Slight twist on the standard window doesn’t drop when opening the door problem, and I could use your help. When I stick my hand in to the area near the door handle and wiggle the wires, the window will drop the proper amount but immediately roll back up, over and over as long as I have hold of the wires. When I put the door panel back on and button everything up, the window stops dropping.
