Lukas Grom
    LA
    Cayenne S 4.5
  • Future cars
    Newer Cayenne
    No info
Lukas Grom's Achievements
  1. Hello I would like to ask other Cayenne S 955 users if you also have a hissing air sound when you turn off the engine?
  2. Hello In the Porsche Cayenne S 4.5 955 car, after unscrewing the oil filler cap, there is sludge on it and a bit inside on the chain. After removing the dipstick, nothing special except oil. You can feel gasoline on the cap and the oil filler. Rust is embedded in the chain. The car does not show any symptoms, from time to time it shows error P0456 (Evaporativ Emission System Leak Detected (very small leak), but it is checked by a normal diag, I do not have PIWIS. The car became unused for 3 weeks. I don't know if rust could form after this time if there was moisture inside. In the second photo you can see part of the chain after starting and stopping the car. Photos(Wait a moment for better quality): https://1drv.ms/f/s!AmU_M2rd38T-h3e0G5Hl9WSoUbGY
  3. I have a problem with it even if I'm at the driver's door. There used to be heavy rain and I wanted to open the car, but before I opened it I was wet
  4. Kessy is keyless? I have the basic version of Cayenne. I have to open and start the car using key.
  5. Unfortunatelly, not. I got one key when buying.
  6. Hello I have one battery. I only have a Bose subwoofer and a spare wheel in the trunk.
  7. Hello I have a problem with my Cayenne S '05. I think there is something with the antenna signal. When I try to open the door with the key, I can do it with about 1-3m. When I drive the car a few minutes and finish, I try to close the door with the key, but the door does not close. I click the button several times, the green lamp on the key lights up and after several attempts the door closes. Sometimes I have to put the key a few millimeters from the door and sometimes help. When after that I wait a moment and tries to open the door is the same problem. It is the same with the window tailgate opening button. The car battery was being charged, the key battery was being replaced. I don't know what the problem may be. I will add that the opening button (the one with the wiper) does not work for the tailgate. https://youtu.be/K-mhKi4iBFs
