Matrixxxx
    York , UK
    2009 GTS
    Lexus ISF 2008.
Matrixxxx's Achievements
  1. its the fibre connections in the square recess that carry the sound?
  2. measure directly on the battery is should be above 12.3 VDC approx. anything below 12V means a new battery.
  3. if the battery is over the warranty period just replace , and it is not a good idea to charge in the vehicle these chargers will cause the battery to produce hydrogen, as gassing is the way of cleaning the plates. Out and on a bench is always best, prevents explosions and any AC getting into the ECUs'. trickle charging is ok in the vehicle. but in normal use a battery should never need external charging. it seems the Cayenne is very power hungry.
  4. I would drill a shallow hole either side of the insert and prise out
  5. Vaccuum leak? check your pipes.
