Newbiecayenne
Everything posted by Newbiecayenne
  1. Ok I have power to the brake booster but it is still not working I disconnected the abs pump and I have exactly the same faults does that mean my abs pump is fried?
  2. Ok guys I’ll give both ideas a go
  3. 2003 cayenne s 4.5 non turbo automatic
  4. 2003 cayenne 4.5 v8 non turbo automatic P1299 gateway p1316 psm control unit p1606 can timeout tcs/edtc Repaired all wiring splices under carpet (both sides) replaced brake light switch replaced battery cleaned earth’s swapped speed sensors from no issue cayenne Warnings are * brake proportioning * 4x4 system faulty * both digital and analog speedo not working still have same problem I’m absolutely stumped
  5. Ok guys I’m a first time Porsche owner and I have a 2003 cayenne v8 non turbo I have a brake proportion error and abs and 4x4 not working also speedo and odometer don’t work I have done the wiring repair as everyone recommends and still no luck changed all 4 speed sensors and swapped out the transfer engine on the gearbox so I’m absolutely stumped any help will be greatly appreciated
