Delforo
Everything posted by Delforo
  1. Thanks so much........!!!
  2. That makes sense. Can I have the P/N's for items 18 and 22?
  3. It does not look like any of those P/N's are the switch itself, but the holder, cover and trim panels. I do appreciate the information provided; if you can dig a little deeper for the switch itself I will be most appreciative.
  4. Difficult to tell in the exploded view. Can you provide the P/N for items 9, 10, and 11? Thanks so much for your quick reply......!!!
  5. I'm looking for the P/N of the buttom to switch on-off the park assist an a GTS '10. Thanks in advance
  6. Any clues about where to get a turbo cluster???????????????? It sounds like a worthwhile upgrade!!! Thanks.
  7. Thank you anyway, very much appreciated.
  8. Loren; Thanks for the quick reply. Attached to this post, please find a picture of the other switches I was referring to (F,G,H,I,J).
  9. Looking for OEM P/N's or alternate P/N's for the Cay '05 PSM type switch and the aircondioning control panel switches (behing the cover flap). I'm looking into adding a few goodies and need a couple of switches but would like very much to keep the OEM look of the panels. Thank you in advance for any clue!!!!!!!!
  10. Thanks Marco......... I will be working on this during the weekend; I will definatly let you know how it went.
  11. The camera is the Pioneer ND-BC1. Look around is everywhere.... I will hook it up to the Nav-TV OPV-1C Fiber optic MOST and CAN Plug and play kit. It will display in the PCM screen when the car is in reverse. I just need some help with the cable routing..................Then I'll report the end results.
  12. Hi all!!!! I'm trying (actually planning) to install a rear view camera in my '05 Cay V6. I think a good place would be just below the rear door handle and above the lincense plate frame (the frame would have to be trimmed to fit the camera. I want to route the cable thur the rear door handle (rubber) into the door and then up to the spoiler and down to the rear LH side of the cargo area. Any ideas on how to remove (access) the rear door linner to get the camera cable routed as described? Thanks in advance for any clues..........
