miguel oliveira
Everything posted by miguel oliveira
  1. First of all Thank you for your reply. Is there a way to know what is the defective part? What I feel is: before starring the car I press the clutch, as the engine buids up speed I feel the pedal going soft. As I start to drive the car ,sometimes between 1st and 2nd gear or neutral and 1st, the pedal gets hard again but goes smoth with another press.
  2. Thanks for your reply. I also want to do the job myself and if no harm is done I will continue to drive like this until I got time for the DIY
  3. I have a 2003 TT with aprox. 72000 kms for 3 years now, and for the last month I have been feeling the clutch pedal getting hard but I also feel the clutch more predictable now. I know this is the clutch accumulator but my question is: does it do any arm to continue to drive the car like this ,or should I replace the accumulator as soon as possible? Thank you in advance Miguel Oliveira
  4. I was finaly able to install the 997 shifter in my 03 turbo, and I have to say that if somebody is in an doubt about doing this it´s a very easy DIY (I follow the BM instructions) and highly recomended. The shift gains a complete new feeling of precision and shortness
  5. http://www.renntech.org/forums/index.php?s...ost&p=65243 Thank you once again Loren :renntech:
  6. I have done a lot of search for the b&m instructions but I can not find them. If someone has it would be great, so I can try the 997 shift . Thank you in advance Miguel Oliveira
  7. Part# is 99742401000 and as per skymast it is about $160.00. Easy to install as long you mark the old push-rods. I have used the B&M shifter installation instruction and it help a lot to do the job.Short Throw shifter installation instructions. Thanks for all the info. I will get the shifter and try to install it I will then post with the update
  8. Hello I have a 03 TT and I would like to improve my shifter, and by all the previous post it seems that the best way is to go for a 997 shifter. My questions are: is it the normal 997 shifter (if somebody has the part number) and if it is a simple replace or do I have to buy something else to do it. Thank you
  9. I got the workshop manuals and PET from the Porschelibrarian. A lot (huge) of useful information on my 996tt, that I think that anybody who wants to get familiar with their car should have. Thank you Porschelibrarian Miguel Oliveira
  10. From what I remenber from the manual, with the key you should turn the ignition on, then press at least 5 sec M + key ( if you want the passenger mirror to move down you should also engage reverse after the ignition ) and only when you open the car if your seat is in different possition it will go back to yours. Hope it helps
  11. I found out that the light from the trunk only works when I take the key from the ignition , and for curiosity , when I open the trunk even if the engine is close the light from there also works.
  12. Thanks Loren Do you have any pictures so I can find it more easy
  13. Hi I have a 2003 996TT, and I feel the same with the clutch only working in the last part, the car has 42000 kms and the pedal feels very light , I would like to try to put some air but I dont Know where is the bleeder for the clutch. Does anyone has pics or detail instructions Thank you all
  14. The only way to remove the PCM 2 ( by the way from a 2003 996 tt) was to remove the dents , and I had to took the car to workshop , so if anyone else try to remove the PCM be careful not to force the plastic pieces as they will brake making it impossible to remove the unit so easily. In my car (LHD- I dont know if it makes difference) to close the detents ( 2 from each side ) is at the left side up and the right side down and the unit should remove easily . After inserting the Pcm to open the detents is oposite. Thank you all :renntech: :renntech:
  15. and it is from Portugal, the code is C27
  16. It is a 2003 996 turbo and with bose amp
  17. HI I just finished the repair on the sim card tray that was just out. everything works, but the phone appears with the message phone not available, does everyone noes if I need to do something else? By the way the instructions on how to replace the card are great :renntech:
  18. Hello In my 996 the sim card from the pcm popped out and it never come back to position again. I ordered the tray from Becker, and today when trying to remove the PCM, when closing the dents from the side I think I broke the plastic pieces that close it ,as only one side is loose and the other does not move , and the plastic pieces goes 360. Is there any other way to remove the Pcm? Thank you in advance :renntech:
  19. Thanks for all the information Miguel
  20. The release lever can only be change whith a new clutch? Thanks Miguel
  21. Thank you for tha advice Miguel
  22. Hello. A have a 99 carrera 4 with 65000kms and I feel the cluth only starts to work when the pedal is almost at the top.I made o lot of experiences and never felt the clutch slip. Is there any adjustment I can do? Should I expect to change the clutch soon? Thanks for all the advice
  23. I have a 99 carrera in Portugal with the same problem. In my car a have a 2002 central europe disc that has only the main roads for us, that means A1 ,A6 and a few more.
  24. I have a carrera with pcm1 of 8 bits.Is it possible to replace it for a 16 bit reader without major chanjes/problems?Your help would be moustly appreciated
