996Carrera
Everything posted by 996Carrera
  1. I pretty sure the dealer use compressed air the last time I had mine cleaned Sent from my iPhone using Tapatalk
  2. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is. Thanks again Loren. I will have the car taken apart next week. When the original dials are out, I will send you the part numbers. Loren, How about this part number 964 641 984 60. Could this be aluminum face with kms with single scale? Thnaks! Yes, it could aluminum face (Canada) only. Interesting it does not show on my parts list - but does show on my price list. Are you saying there is a code with this part number which refers this a Canada only gauge? Could you please give me the price? Thanks.
  3. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is. Thanks again Loren. I will have the car taken apart next week. When the original dials are out, I will send you the part numbers. Loren, How about this part number 964 641 984 60. Could this be aluminum face with kms with single scale? Thnaks!
  4. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is. Thanks again Loren. I will have the car taken apart next week. When the original dials are out, I will send you the part numbers.
  5. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list?
  6. Hello, I am a looking for the 993 P/N for a Tequipment aluminum faced speedometer gauge with kms. Any help would be much appreciated. This is for a Canadian 1996 C4S with no OBC. TIA
  7. Hi Loren, thanks for all the help! 1996 C4s BE 2282 T5001313 Thanks again.
  8. Loren, thank you for the quick response. Can you please tell me which part number would be for the tach in steel grey for Canada and no OBC? I don't understand what 480 and 495 stand for. Thanks again.
  9. Does anyone have the part numbers for the 993 aluminum/grey faced guages for a Canadian car with no OBC. TIA
  10. Gabo2K, I bought the the C4S front lip for my turbo bumper and it fit perfectly. I was going for the 40th anniversary look with my GT3 side skirts. My bodyshop did the all the work on my car. Look here for DIY bumper install with pictures http://www.6speedonline.com/forums/showthr...ht=turbo+bumper I don't have a rear turbo bumper, so I can't help you with that. You might want to try Doncapecod on 6speed or rennlist. I know he has installed a genuine rear turbo bumper. If you want some pics of the finished product I can send them to you.
  11. I recently installed a turbo bumper on my C2. I didn't want that gap, so I searched for the parts used on the 40th anniversary. The part I found was called an air baffle/inlet, it surrounds the inside of the center grill and extends down to the mounting points of the body. The gap is completely gone with this part. The piece is quite large and qiute expensive but secures everything nicely. Tha part number is: p/n 996 504 085 00 707 It costs around 560 cdn wholesale or 700 retail. I also bought these parts: two headlight trim-996 505 741 02 -996 505 742 02 two finder liner extensions- 996 504 124 00 - 996 504 123 00
  12. Thanks for the quick response.
  13. Can you please tell me which type and color these ebrake part numbers belong to. Thanks Dan 996 424 980 02 8yr 996 424 980 02 c50
  14. Thanks a lot for the info, can you tell what 996 111 985 01 is? <{POST_SNAPBACK}> I understand which part# is for the current pse, but I am trying to buy a used pse from 01 C4. The part# he gave was 996 111 985 01. I have a 02 C2 and was wondering if it could fit or can be modified. Thanks
  15. Thanks a lot for the info, can you tell what 996 111 985 01 is?
  16. Can you please tell me is this a pse part # that would fit a 2002 C2
  17. Could you please tell me what these are? 996 6129 7800 3a 996 0600 0044 996 0600 0017 Thanks
